FE Technical Forum
parallel main oil galley
Topic: parallel main oil galley (Read 3162 times)
allrightmike
Sr. Member
July 25, 2019, 02:25:25 PM »
Has anyone ever herd of running a parallel main oil galley in a center oilier fe in the lifter chamber by drilling & pipe taping at each end? Maybe 3/8 steel tubing. Might help those #4&8 rod bearings live a little longer? Stop laughing!
Mike.
'60 Starliner 427 4speed.
GerryP
Re: parallel main oil galley
Reply #1 on:
July 25, 2019, 02:56:57 PM »
There have been priority main oiling modifications done to center (top) oiler blocks. They are quite the engineering feats. They get posted here or on the other forum from time to time.
What gets lost is the purpose of the Ford sideoiler block. Same for oiling system modifications.
Reply #2 on:
July 25, 2019, 04:06:03 PM »
I remember seeing that in Clevelands, for like Pro stock racing days.
I can't see the advantage in anything other then a top of the line, super high rpm engine. Too many build these days that run for a long time without all that mess.
Ranch
Full Member
Retired Maintenance Machinist, Millwright
Reply #3 on:
July 25, 2019, 07:04:46 PM »
I don't know if it's a good thing or not, but the $$$$ steel crank being crossed drilled 4&8 rods are being fed from 4&5 mains and theoretically is being fed from #1 main. But that's getting a little overboard.
C8OZ
Full Member
Reply #4 on:
July 25, 2019, 09:02:42 PM »
And if you just can't get enough side-oiling:
https://www.ebay.com/itm/427-Side-Oiler-FE-FORD-PRO-Stock-Engineering-Engine-w-nos-fit-Cobra-Mustang-/123761697828
FE Technical Forum
