Author Topic: Stock High Riser Head Flow  (Read 4037 times)
jcooper
« on: July 02, 2019, 04:18:32 PM »
Sorry in advance if this has already been covered but could not find searching. Does anyone have int/exh flow numbers for stock ford high riser heads? looking into a couple different combinations and would like to have a flow to compare. Thanks in advance
Jerad Cooper
-2002 Dragster, 498 FE Powered
-1964 Galaxie XL, 427 FE Powered
Re: Stock High Riser Head Flow
« Reply #1 on: July 02, 2019, 06:00:53 PM »
« Reply #2 on: July 02, 2019, 06:10:58 PM »
I have ported several sets of HR heads recently, repaired several, and reworked a couple for folks.  Stock the -F heads flow ~ 285/190, but most will flow 330/230 with a basic good hand porting.  2.250"/1.725" valves will increase this some and a really good porting with someone who has experience with the short turns can get 350/260 cfm.  I recently filled the floor on a set with epoxy and changed the size to MR, and with a bit of finesse, they went 370/260 without a tube on the exhaust.  I don't have the flow sheets handy, but the HR has one of the best exhaust ports of any FE head that I have worked with.  Joe-JDC
« Last Edit: July 02, 2019, 06:15:18 PM by Joe-JDC »
jcooper
« Reply #3 on: July 02, 2019, 06:51:27 PM »
Wow, that is impressive that you filled in nearly 25% of the opening and got that large of an improvement.
Jerad Cooper
« Reply #4 on: July 02, 2019, 09:34:33 PM »
Those heads are going on a 482 with Jay's HR adapter and 351C tunnel ram that I worked over.  Should be a beast.  Joe-JDC
