Author Topic: engine limit strap location?  (Read 3423 times)
Jim Comet
« on: June 24, 2019, 09:04:13 PM »
How do you all feel about me attaching my engine torque limit strap to this hole on my aluminum heads. Is there any concern about cracking the bolt hole? should I build a bracket that attaches to both the bolt holes on the front of the head and attach my limiter to that? The car has a 5500 converter and will launch on slicks so it may be tested. I love not having shock towers. I just installed the passenger side header in 20 minutes and the drivers should take about the same. Jim
« Last Edit: June 24, 2019, 09:17:34 PM by Jim Comet »
CaptCobrajet
Re: engine limit strap location?
« Reply #1 on: June 24, 2019, 09:19:44 PM »
Yes, make a bracket that uses both bolts.  Use Heim joints on either end.  Never has hurt my junk.
Blair Patrick
winr1
« Reply #2 on: June 24, 2019, 09:25:14 PM »
I agree with Blair
Ricky.
« Reply #3 on: June 25, 2019, 10:47:22 AM »
Nearly same setup in some iron heads, been running that way for years without problems.  Heim ends make it nicer, mine are build from 3/8 all thread with a hardware store aluminum screen door adjuster and some lock nuts.
« Reply #4 on: June 25, 2019, 02:11:51 PM »
I use the same bolt hole for over 20 years on my aluminum heads
66FAIRLANE
  • Andy
« Reply #5 on: June 25, 2019, 05:26:52 PM »
I used this hole also for 20 years on my Edelbrock Heads although my strap is bushed at the bottom (leaf spring bush). Can be seen in this pic.
« Last Edit: June 25, 2019, 07:42:51 PM by 66FAIRLANE »
