Author Topic: Replacement radiator  (Read 9451 times)
Dieselman966
« on: June 10, 2019, 10:33:55 AM »
What are you guys using for replacement radiators.  My stock one needs to be record and will cost $600 locally.  My as well upgrade if its gonna cost that much.
Re: Replacement radiator
« Reply #1 on: June 10, 2019, 11:36:55 AM »
Personally, I think U.S. Radiator is the best there is. They have several different options to choose from and the quality is second to none.
http://www.usradiator.com/
WerbyFord
« Reply #2 on: June 10, 2019, 11:43:23 AM »
I got an American Eagle (very American-looking box and Eagle) about 4-5 years ago for our 64 Gal, about $200.
Aluminum, car runs 10-15 degrees cooler, total bolt-in from brackets to trans cooler lines.
I painted the tanks black & nobody even notices its in there.
Dr Mabuse
« Reply #3 on: June 13, 2019, 12:13:02 PM »
Rock Auto
RustyCrankshaft
« Reply #4 on: June 13, 2019, 06:20:59 PM »
I've bought American Eagle radiators for a few projects and for the money they're pretty hard to beat. US Radiator is good, very authentic looking and you have a lot of core options, but you also pay a premium. Hard to go wrong with either one.
« Reply #5 on: June 14, 2019, 08:25:05 AM »
« Reply #6 on: June 14, 2019, 11:17:35 AM »
you can get a Champion aluminum radiator for under 200.i know they are cheap ,but i put one on my car about 3 years ago and my temp has never been over 190 in any situation,and it fit like a glove.all i did was dropped it in and hoked it up
« Last Edit: June 14, 2019, 11:21:48 AM by fryedaddy »
« Reply #7 on: June 14, 2019, 12:56:04 PM »
On the Falcon I use a Summit dual core aluminum with 1" cores.  Works good, but you'll have to totally engineer the install.  It's generic at 31" x 19".
Dieselman966
« Reply #8 on: June 14, 2019, 02:00:29 PM »
I ended up ordering one from radiator supply house. Supposed to be a drop in radiator that will take the stock fan shroud. Well see what it looks like when it gets here.
olman
« Reply #9 on: June 14, 2019, 03:01:42 PM »
Does the 63 have the same dimensions as the 64 radiator?Mine is a single core original and would like to go to a 2 core because of the 428 engine. And what about a shroud?
RustyCrankshaft
« Reply #10 on: June 14, 2019, 04:18:39 PM »
If you don't mind Chinese the Champion's are good. Leadfoot has been good about customer service so far in my experience. I bought another one, for a 73-79 4x4 radiator from them for my crewcab and had to exchange it because it showed up with a UPS footprint in the middle of the core and no drama, they took care of it. They work fine and they're inexpensive.
Dieselman966
« Reply #11 on: June 15, 2019, 11:44:41 AM »
Rock auto does not carry radiators for a 65 galaxie with an fe engine.  They only have them for galaxies with SBF engines and those radiators dont have the inlet and outlet on the same side
Dieselman966
« Reply #12 on: July 05, 2019, 01:10:50 PM »
How much difference is there between a 64 galaxie radiator and a 65 one. The radiator supply house has sent the wrong one twice now.  Think I’ll just get a refund and move on now.
shady
« Reply #13 on: July 05, 2019, 04:18:28 PM »
61-2-3 are the same, 64 is by itself, 65 is different also.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Ranch
« Reply #14 on: July 08, 2019, 07:09:22 AM »
I still have my old 62 crossflow from a '406' I had a filler neck put on it to get rid of the expansion tank. This is for a manual transmission car.
