Author Topic: 410 Street Build  (Read 56576 times)
Re: 410 Street Build
« Reply #15 on: June 11, 2019, 10:52:27 AM »
I think a Comp 268H would be nice given the gearing, vehicle weight, and low rpm goals.  Just have to make sure to match the compression ratio.  9.5:1 or thereabouts.  It might not make 400 hp, though.
JMO,
paulie
« Reply #16 on: June 11, 2019, 11:24:06 AM »
Hello gentleman. I thought it might be kind of fun to document my 410 engine build slated to go into a 1989 F-150 2wd short bed.
This may take some time as most of my projects usually do.  :)
The goal is to have as much torque and throttle response as I can possibly get while keeping within:
A) Stock or near stock torque converter.
B) 3.08 rear end gears.
C) Good vacuum for power brakes.
D) Target of 400 horsepower.
Werbyford outlined a nice, basic build for me here http://fepower.net/simplemachinesforum/index.php?topic=7463.0 that I most likely will follow. However, I would really like to go with a hydraulic cam, if possible, that would run like the 270S.
Any and all input is greatly welcomed and encouraged.  :)
And since we all like pics, here's what I'm starting with.
I'd do one of my custom hydraulic flat tappets:
227/235 @ .050", 111° LSA, 105 ICL, .528"/.540" lift.  61° of overlap for power brakes, higher advertised durations to keep you out of pump gas problems with 10:1 compression.
410bruce
« Reply #17 on: June 11, 2019, 08:20:33 PM »
Thanks for the input so far guys, it's really appreciated.  8)
Brent, I'll be talking to you when I get to the point of cam installation.
I do like to give my business to people who freely share their knowledge on these forums. Thank you.
John 3:16
410bruce
« Reply #18 on: June 19, 2019, 08:01:59 AM »
The crank is at the machine shop.  8)
I sold a marine 351w to a gentleman from the Redding area and asked if he knew of the shop I wanted to send the crank. He said yes and not only that, had previously had them do work on his Y-block and was very happy with the work.
Anyhow, I asked him if he would mind delivering it to the shop for me and he was happy to. Nice kid.
I took a little off the price of the 351 for his trouble.
So, waiting to hear back if the crank is salvageable.
John 3:16
« Reply #19 on: June 19, 2019, 08:39:41 AM »
Does an FE bolt right into an 89 pickup?. I thought 76 was the last year for that because of crossmember issues.
410bruce
« Reply #20 on: June 19, 2019, 09:49:23 AM »
No, it does not. But, where there's a will, there's a way.  :) You are correct about 1976 being the last year for the FE in pick-ups. Could have been some left overs in '77.
I used to have a 1979 F-100 2wd sb that went through a series of engines. It came with a 302 then I installed a 351C 4V CJ, 460, 460, 429, 428, 460. All of them I was able to use the stock engine mount perches. However, as I recall, I had to move them either forward or back for the 428.
The '89 has a 300/6 in it right now and I will have to change perches. I'm hoping to use the 5.0/5.8 perches and just mount them where the 410 needs them.
I'll share my installation once it's all together.
John 3:16
BigBlueIron
« Reply #21 on: June 19, 2019, 03:25:32 PM »
[/quote]
[/quote]
You sir are hard on engines and a glutton for punishment! I'd like to see how it turns out.
RJP
« Reply #22 on: June 19, 2019, 06:57:33 PM »
410bruce, What shop did you send your crank to? I'm in the Bay Area and the last crank grinder just closed up shop a week or so ago. I know of no shops in my area that grinds cranks which would mean I will have to travel to get a crank done. Any help? TIA
67428GT500
« Reply #23 on: June 19, 2019, 07:49:32 PM »
Bay Area? I'm sorry..lol
410bruce
« Reply #24 on: June 19, 2019, 09:16:02 PM »
[/quote]
[/quote]
Lol. Nah, it was more experimentation than anything. Thanks.  8)
John 3:16
410bruce
« Reply #25 on: June 19, 2019, 09:20:14 PM »
L&M Grinding in Redding, CA.  http://www.buzzfile.com/business/L.And.M-Grinding-530-221-7652
Pretty hot over there right now. His hours at this time are 6:30am-2:00pm Tuesday-Thursday.
Owners name is Mario. Really good guy to deal with.
John 3:16
410bruce
« Reply #26 on: June 20, 2019, 11:03:40 AM »
Just spoke with Mario on the phone. Cranks done. Mains cleaned up at .020 and the rods at .010. Excellent!  :) :)
John 3:16
67428GT500
« Reply #27 on: June 20, 2019, 12:55:30 PM »
Did you have him grind to the low side of tolerances?
410bruce
« Reply #28 on: June 20, 2019, 08:42:52 PM »
I left it up to him. I would imagine he set it up at whatever clearance Ford calls for.
John 3:16
67428GT500
« Reply #29 on: June 21, 2019, 10:21:14 AM »
As a habit, I have always had them grind to the low side of tolerance to allow for adequate clearances. I try to keep .002-.0025. Better than playing the bearing game being there are few offerings if the clearances are an issue short of returning the crank to the grinder. Make sure they did a nice chamfer for you as well.
I can't wait to get home this week.  Don't mind me.
        -Keith
