Author Topic: Question for Brent  (Read 8473 times)
Re: Question for Brent
« Reply #15 on: June 10, 2019, 01:11:12 PM »
mine busted through all eight holes but only one or two leak.but thats one or two too many.  can the incerts be taken out and can those keencerts be put in without removing the heads
« Last Edit: June 10, 2019, 01:12:43 PM by fryedaddy »
« Reply #16 on: June 10, 2019, 01:15:22 PM »
You should be able to do that dip the tap in grease so the
shavings get stuck in the grease
« Reply #17 on: June 10, 2019, 01:23:00 PM »
i could remove the intake and catch it from the bottom of the holes
« Reply #18 on: June 10, 2019, 01:29:18 PM »
yes that to,
wowens
« Reply #19 on: June 11, 2019, 02:12:57 PM »
Per Harland Sharp tech their stands are 1.375 stand mounting base to shaft centerline
Woody
« Reply #20 on: June 11, 2019, 02:36:23 PM »
If I remember correctly, the Comp set was about 1.400".  I think the POP stands showed a ~1.400" height as well.
