Author Topic: machine shop cant align bore block  (Read 19963 times)
gregaba
Re: machine shop cant align bore block
« Reply #60 on: June 12, 2019, 02:18:03 PM »
Job is done.
The left side wasn't quite centered so on both sizes I stepped up though 5 drill sizes and was able to take a hammer and chisel and collapse the plugs into themselves. I knocked them out and ran a final 13/32 drill though the holes and retaped  them to 7/16 x 20. I was able to catch a little thread on each hole so the tap job was easy.
Took about an hour.
Thanks for the ideals and help.
Greg
« Reply #61 on: June 12, 2019, 04:02:54 PM »
My metod takes 15 minutes ;)
gregaba
« Reply #62 on: June 12, 2019, 04:16:05 PM »
Yeah Heo
but I am a glutton for punishment.
Greg
« Reply #63 on: June 12, 2019, 06:36:03 PM »
I thought all block drains were 1/4" NPT? In that case, 7/16" is the drill size. Also, with a straight thread you may have a problem sealing it there and getting the plug tight with no taper.....
gregaba
« Reply #64 on: June 12, 2019, 06:41:39 PM »
These two plugs were 7/16. I don't know why they would be different but on my older motors they were 1/4 inch.
Hoping my thread sealer will seal it, if not I am not above using epoxy even though I hate not being able to clean the block the next time I build it.
Greg
67428GT500
« Reply #65 on: June 12, 2019, 10:59:18 PM »
They are 1/4 NPT. Which is about 7/16.  Just re-tap them for 1/4 NPT.  If you want to use the O/E hex head plug they are available from AMK fasteners.
        -Keith
gregaba
« Reply #66 on: June 13, 2019, 09:22:44 AM »
Thanks
Will do.
Greg
« Reply #67 on: June 13, 2019, 09:40:37 AM »
Drill it out almost to size and run a tap thru it. Holes look pretty centered.
Yea, pretty well centered for using an ice pick the make the hole.
