Author Topic: Lykins Motorsports non-adjustable roller rockers in stock, 9.26.20  (Read 19323 times)
Another shipment coming in Monday.
« Last Edit: September 26, 2020, 05:29:03 AM by blykins »
67428GT500
Donating parts?  8)
Yep, $450 and I'll donate a set to any cause.
Hey, pay $900 for one set and I'll even throw a set in for free.
67428GT500
I have dove rollers, but if I break one I will definitely be coming to you.
shady
My motto is charge double and give 50% off.  They are pretty, I just couldn't resist taking a peek at them.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Rockers are here.  Get 'em while they're hot.
I can also package these up with HS shafts and POP stands.
Brent, I need a third set, keep them coming!
FYI - If any of you are on the fence, what an easy decision during a build.  I was going to do a write up, but what kind of write up can you do when you just bolt them on, check pushrod length, buy cheaper pushrods because they are common size, gain pushrod clearance, etc?  They are just easy and nice.
Also FYI - They fit at .630 lift under PBF valve covers if you squeeze the baffles a little with a pair of channel locks...easy job, at more normal lift, I'd expect no issues at all, and tons of room with pentroofs, both cast alum and steel
I guess that was a write-up   :o
Arizona ‘58Mercury
So what’s it run for the whole set up?  Rockers, shafts and pop ups
Pop ups?  You mean stands?
Arizona ‘58Mercury
Yes, I miss read what you put above.
Re: More Lykins Motorsports non-adjustable roller rockers are on the way....
« Reply #10 on: August 14, 2019, 01:09:35 PM »
Complete kit for a LR/MR combination would be $910, including rockers, HD shafts, billet end stands, billet center stands, and billet spacers.
Arizona ‘58Mercury
« Reply #11 on: August 14, 2019, 01:42:01 PM »
I got my cam and lifters through you, I’ll be in touch on these as well.  Thank you
« Reply #12 on: August 14, 2019, 03:58:09 PM »
Sweet deal Brent !!
Sand hauler
« Reply #13 on: August 20, 2019, 08:31:13 PM »
Can I use the PAC 1940 springs with these,or would I need to use a smaller dia spring?
Bobby-   Carlsbad, NM
« Reply #14 on: August 21, 2019, 04:38:36 AM »
They will clear/fit just fine.
