Author Topic: TL not going all the way in. Will lose mind soon.  (Read 12448 times)
6667fan
  • Every Second Counts
« on: May 19, 2019, 05:45:02 PM »
Get as far as the retaining collar mounting flange  just inside the bell opening, so about .375 to go. Using lower guide pins, bell was dialed to within .010 out of center from left to right. 12 to 6 was near even.
Tried having someone depress clutch and wiggling trans. Used plastic alignment tool when clutch was bolted on. O.D. of tool and input shaft match. Rotated engine a few degrees with breaker bar in between attempts to get trans home. Thinking of scaring up a input shaft and installing it and  taking some measurements to see if disc is centered. All this finagling is done from under the car and it is getting old.
Thoughts?
Thanks,
JB
« Last Edit: December 16, 2020, 08:08:52 AM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Yellow Truck
Re: TL not going all the way in. Will lose mind soon.
« Reply #1 on: May 19, 2019, 07:50:34 PM »
First time I did this (as in first time I ever installed an engine - I'm only on #2 but the second one was a breeze) I resorted to taking off the inspection plate, rotated the clutch and backed off all the clutch to flywheel bolts, and let it float a little. While one guy messed with the engine and another rotated the crank a little, I moved the clutch back and forth a tiny bit and it finally seated, then rotated the engine slowly and tightened the clutch through the inspection plate.
Not elegant but at the end of a long and very frustrating day got it done. I think we took the engine out 5 times and redid the alignment. One guy was an experienced junkyard builder and the other a journeyman mechanic, so it wasn't their first install.
Paul.
« Reply #2 on: May 19, 2019, 08:01:30 PM »
Sometimes the sun and moon are NOT in phase and seems it will never go.   Sometimes I fight for 1/2 hour, then just roll out and take a deep breath, relax and then roll under and it literally FALL into place.
I use old input shaft for alignment.  Even though, you can get slop as the disc will pull down on the dummy shaft.  I usually wiggle it in out a few times after tightening the pressure plate to make sure it's not dragging on the pilot bearings and actually some what below centerline.
If you have someone with you, then can get in the car and push clutch as you wiggle.  Sometimes that helps.  Don't get over zealous, as you don't want to have to pull it apart if the disc falls out of location.
« Reply #3 on: May 19, 2019, 09:52:46 PM »
What kind of bell? I've had to lightly 'clearance' the retainer opening in one of my Lakewood housings because the retainer was just too snug to draw up properly. I just took some heavy sandpaper around the insides until it slid in easier.
Otherwise, like Larry said, sometimes you just have to take a break and walk away, try again later, and sometimes it'll just slide in then. I never like to depress the clutch because it can move and be off alignment then. If the clutch plate is centered with an alignment tool or input shaft, and it can be eyeballed pretty accurately afterwards to make sure it is correct, then you shouldn't have to touch it. Getting the transmission on a perfect center, on 2 different planes (vertical and horizontal), can be hard sometimes, even when you swear it's right on. I keep telling myself I'm going to get a proper trans jack, but I'm too cheap and always do it by hand, balancing on a floor jack. ::)
« Reply #4 on: May 19, 2019, 10:16:28 PM »
Is it a small block top loader?  Will not go all the way in on FE unless you modify/shorten pilot shaft.  Joe-JDC
« Reply #5 on: May 19, 2019, 10:37:04 PM »
2X to what Joe said.
Also, if it's new Lakewood bell (or maybe even a lightly used one) be sure to sand away all the red paint from the i.d. edge where the front bearing retainer sits. Amazing but this is sometimes just enough paint to keep the tranny from seating.
427Fastback
« Reply #6 on: May 19, 2019, 11:12:01 PM »
I use 2 long 7/16 bolts that I cut the heads off and squared the ends.I use them for studs to line it up and support the weight.
I too have struggled doing it but is sounds like something is not quite right here...
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #7 on: May 20, 2019, 01:40:09 AM »
What bellhousing and trans vintages are you using? On my 59 Ford 2 door sedan, I have a 428 Cobra Jet engine, a 1966 small block wide ratio Toploader, and a 1961 cast iron bellhousing. The early (pre 65) Ford manual transmissions use a smaller bore size for the transmission front bearing retainer than later models, so I had 2 options. I could either find a 1964 only Toploader bearing retainer, have the larger retainers OD machined down to the earlier size, or do as I did, and have a machinest bore the early bellhousing to the later size (4.84").
Concerning the small block vs FE input shaft length, yes, the small block input does have a slightly longer pilot tip, but on my car, I mocked up the engine/trans/bellhousing without a clutch or flywheel, but with a pilot bushing, and, at least with my setup, the small block input had enough space to allow the trans to go all the way in, and still have sufficent space between the pilot bushing and the splined section of the input shaft without needing to trim the tip of the input shaft. Like Larry said, a old steel input shaft fits much better than a cheap plastic line up tool , if the input shaft slips in and out of the clutch when its all bolted together, the disc is centered, and there should be no need to loosen the pressure plate bolts, or depress the clutch pedal to make it all fit. Like others, I have had the odd occasion where the trans didn`t want to go in properly, walking away for a bit, then retrying the install with a fresh attitude, usually does the trick. before installing the clutch assembly, did you test fit the disc onto the input shaft, to confirm the disc slid easily onto the inputs splines? Check that the new throwout bearing easily slides all the way along the bearing retainers sleeve? That the pilot bushing fit properly over the tip of the input? Often, even if your attempt to install the transmission has the input tilted just a little bit can prevent an easy install.
« Reply #8 on: May 20, 2019, 04:36:18 AM »
Pilot bushing or bearing?
6667fan
« Reply #9 on: May 20, 2019, 07:10:25 AM »
I proved the bell mouth had no interference with trans while trans and bell were on the shop floor so there is not an interference there. The bell is a new older Lakewood that I have not used before that was purchased from a forum member. It is the same depth as my old Lakewood that I have run with my David Kee TL.
What I did not do was test install the trans into the bell/engine while the engine was on the shop floor. Did not anticipate any problems but I will ALWAYS do that going forward.
Regular bronze non roller bearing.
If I’m less that a half inch from home can I assume I’m not into the bearing at all? The tip of the input is longer than a half inch. Or I should I assume that the input is slightly off centerline and against the face of the bearing?
I will be looking for a real input shaft today. The plastic guide is too short to take measurements off or provide enough leverage if I want to move the disc a little while someone depresses the pedal.
Thanks for all responses.
JB
JB
67 Fairlane 500
482 cid 700/617
The Real McCoy
« Reply #10 on: May 20, 2019, 08:00:37 AM »
I had a similar issue when installing a TKO 600, wouldn't quite go all the way in. My issue was the input bearing retainer tube (the part the throw out bearing rides on) was bottoming out on the hub of the clutch disc. If this combination of parts has been assembled before it is probably not your issue but a remote possibility.
To verify requires pulling the clutch disc and pressure plate back out as there is no way to see it bottoming out when it is assembled. If the transmission now slides right in, back the transmission up just enough to slip the clutch disc on the input shaft (without the pressure plate) and then see if it slides all the way in. If it doesn't you should be able to see the tube contacting the clutch disc hub.
As I said earlier this is probably not your issue, but.....
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
chilly460
« Reply #11 on: May 20, 2019, 08:19:46 AM »
Yep, they can be rough sometimes.  The TKO in my Merc is always a bear to get to pop in, usually I do the trick with using some studs in the bellhousing to help align the trans.  What I've found is that the holes in the bell are skewed just enough that using the pins in the Quicktime bell will not let the transmission bolt up, have to put it in "freehand".
6667fan
« Reply #12 on: May 20, 2019, 08:56:33 AM »
Response to The Real McCoy: I will check via careful measuring of collar depth to trans face to hub face. This combo has not been assembled previously. The disc is a ceramic/ ceramic paired with an older McCleod cover plate. I understand your test recommendations but I don’t want to have to pull that shit apart to find out!
Thanks for contributing,
JB
JB
67 Fairlane 500
482 cid 700/617
The Real McCoy
« Reply #13 on: May 20, 2019, 10:04:58 AM »
JB, I get the part about not wanting to do a complete disassembly to see if this is a factor.  I also agree because your dealing with about 3/8" (.375) you should be able to make some measurements and determine if this is a factor.
My deal was a bit different, I don't remember the exact dimension but seems it was about a 1/16".  When installing the transmission the case actually "clunked" up against the bell housing.  I was fortunate to notice it didn't feel right when tightening up the transmission mount bolts.  I was within a whisker of total disaster, either snapping an ear of the transmission body or tearing up the engine thrust bearing upon start up.
Hope you get it resolved quickly and easily.
63 1/2 Galaxie 500
MeanGene
« Reply #14 on: May 20, 2019, 03:25:33 PM »
Didn't see a response to this, did you miss it? Check the ID tag on your trans to verify that it is a big-block or small block trans. Small-block input is longer, and causes that exact problem, won't go in all the way
