Author Topic: Anyone wanna play guess the HP/ Torque? There is a small prize for the winner  (Read 14148 times)
6667fan
  • Every Second Counts
Newest version of 482 supposed to go on pump in the near future. Last version number 1 exhaust valve had a (too close) encounter with the piston in September. That P block has had number 1 sleeved, the block bored to 4.265 and bagged. New engine built on NOS ‘71 block. Using the Scat forged crank and 6.7  H beams from P block.
Key particulars: 11-1 CR, (Mahle w 1.5,1.5,3mm), Barry’s Felony CNC heads from October’s EMC. Comp beehives manipulated to 525/200 pressures.
Lykins Custom Hydro roller, (Comp Cams). 255/263 @.050, .625 lift, 112 LSA installed on 108 ICL.
Morel short travel lifters also via Brent. Erson rocker shaft assemblies with 3/8” push rods.
Victor intake via Jay Brown that has been massaged much but is around 3/16” narrower than the ports on Barry’s heads. Quick Fuel Street Q 950 cfm carb via Brent.
MSD ready to run distributor with phased rotor. If my Crites 2” O.D. tubes fit the Dyno they will be used otherwise it will be whatever 1-7/8” mongrel pipes are available at the builder’s shop.
Canton deep pan with tray, Melling HV pump.
Terms: person closest to uncorrected peak HP without going over wins a $25 gift card. Closest to peak torque gets honorable mention. Pro builders please play!
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
I will get in early with the winning entry... 587hp.
 Need my address to send that gift card?
70bosscat
I'll go in for 599.
mike7570
Uncorrected right ?
Where is the dyno located, it could make a difference if it's in Denver or San Diego.
550’
630hp
585tq
« Last Edit: April 19, 2019, 11:37:41 PM by mike7570 »
My 2" Crites Mustang/Cougar headers fit on a DTS dyno.  Just FYI.
paulie
shady
576hp 516 tq
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
6667fan
550’ above sea level.
Paulie, thanks for your the tip about the tubes. I would of course prefer to use them.
JB
JB
67 Fairlane 500
482 cid 700/617
Uncorrected 595 TQ
Uncorrected 627 HP
604 HP
579 Torque
Sounds like a nice setup, what is she going in. Maybe we can guess a 1/4 mile time also.
Not that it’s gonna be at the track by the time this post is done but just a little extra fun.
10.69  @ 128 QMile
« Last Edit: April 22, 2019, 06:48:57 AM by Stangman »
teammoose
612 hp, 597 tq
6667fan
Stangman,
It’s going in my 67 Fairlane 500. Car has a wide ratio DK all aluminum TL and 4:11s. with too tall drag radials, (275/60/15).
 Car needs a shorter bias ply slick or more gear or both. Also a slipper clutch and a different trans. Oh, and a better driver too.  So if you guess an ET aim high!
Good luck with the upcoming carving.
JB
« Last Edit: April 20, 2019, 05:59:50 AM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
69Shakar
615 hp 590tq
64gal482
603 hp, 587 tq
Jose
621hp+581tq
