Author Topic: FE Power Cylinder Heads  (Read 210764 times)
FElony
Re: FE Power Cylinder Heads
« Reply #330 on: March 02, 2020, 10:22:35 AM »
...  I just wish I had a vehicle that could use them, for I have a 530 CI FE shortblock that would be ideal for them.  Joe-JDC
Gots any partickee ler body style in mind?
« Reply #331 on: March 02, 2020, 10:44:10 AM »
What the...............^
FElony
« Reply #332 on: March 02, 2020, 10:51:21 AM »
Doanchoo gno Merikan? I was asking Joe if, perhaps, he had a preference for a certain FoMoCo conveyance that could house said 530. Sheesh!   ::)
« Reply #333 on: March 02, 2020, 11:02:18 AM »
When I made the statement about Jay's heads, it was a bit "tongue in cheek" to stop the nit picking about the heads fitting shock tower cars and him coming up with new ideas for more options.  He has done a massive undertaking with this project, and should not be nit-picked to death about the little things at this time.  His heads are for serious folks who want to make massive amounts of horsepower without killing the parts to get it.  I just wish I had a vehicle that could use them, for I have a 530 CI FE shortblock that would be ideal for them.  Joe-JDC
No worries. I understand what you mean now.   I was just shocked at the way you wrote it and had a knee jerk reaction.  Sorry about that. And I also understand that devices like winglets can reduce overall drag even though they themselves add drag.   Interesting stuff for sure.
paulie
« Reply #334 on: March 02, 2020, 12:15:34 PM »
Got rid of my '69 Mach I with shock towers cut back, so I don't currently have anything short of a late model Fox body.  That gives me an idea---
On the AWACS dome, when I was still active duty, the aircraft were restricted to a certain MPH because of stresses caused by the domes to the aircraft structure.  The aerodynamics have improved, but I think if you were to have access to the flight manuals, there is still a speed limit on the airframe.
FElony
« Reply #335 on: March 02, 2020, 12:26:10 PM »
OK, just checking in case you were thinking lightened Galaxie roller or something.
« Reply #336 on: March 02, 2020, 12:48:10 PM »
Some shapes are aerodynamically inert.  An example:  The radar disc on an AWACS plane neither lifts or drags.
That makes no physical sense.  Where did you get that idea?  You could have neutral lift at some specific speed under certain specific conditions, but zero drag?  That is simply ridiculous.  Where did that idea come from?
paulie
Actually the AWACS radome does create extra drag, but the shape creates enough added lift so that the overall lift/drag ratio is not adversely impacted.
In some cases adding things (drag) can even increase overall efficiency.  Take the winglets that have sprouted on nearly all commercial aircraft.  They add drag, but the energy recouped from the wingtip vortices more than makes up for it!
I read somewhere that. The "Pro Stock" scoop under the belly on the Mustangs that is for
the radiator Ads drag but the increased volume of the air heated by the radiator creates a
"Jet" propulsion that more than compensate the drag. It was called....something,something effect
« Reply #337 on: March 02, 2020, 01:03:45 PM »
Just astounded at your presence. As most folks are when you walk in a room I’m sure. ;D
Nice to hear from you.
« Reply #338 on: March 02, 2020, 01:15:19 PM »
Jay,
Just curious if you thought about making or 3D printing any mock up (dummy) heads for engine mock up and header fab in chassis?
Keith, I could do that but it would be more expensive than you'd think, probably $600 per head by the time the plastic and print time is taken into account.  So, I really wasn't planning on doing that...
« Reply #339 on: March 02, 2020, 02:46:36 PM »
paulie
I'll try to control myself with this thread hijack, but I did spend a lot of time in the aeronautical engineering labs at school.  Heo - you're describing the Meredith Effect.  The same thing was used on the P-51 Mustang to generate extra thrust from the belly-mounted radiator duct:
https://en.wikipedia.org/wiki/Meredith_effect
OK - I'll shut up now.  I promise I'll be posting more relevant stuff in the near future!
- Bill
« Reply #340 on: March 02, 2020, 02:51:41 PM »
No! Bill, we want to hear more from you!
Gee, we could also use you over on the old FE Forum too!
« Reply #341 on: March 02, 2020, 03:50:47 PM »
paulie
- Bill
I'll stop too.   :-X   Just gotta say that I don't believe the radiator on the Mustang actually produces a net thrust.  People talk about it like it does.  Anytime energy is moved or changes from one form to another, some is lost.
It reduces the net drag of the cooling system for sure.   The laminar flow wing deal is debatable, too.
JMO,
paulie
« Reply #342 on: March 02, 2020, 04:47:22 PM »
Thanks Bob!  I've got a couple of cool projects I should be posting about in the next couple of months.  As for the other forum, the Tapatalk privacy sinkhole is not my cup of tea.  I'm always reachable here though!
runthatjunk
« Reply #343 on: March 03, 2020, 10:06:30 AM »
paulie
- Bill
COOL!  It's posts like this that keep me coming back, I would not have ever thought using the waste heat from cooling system could reduce drag or potentially give some amount of thrust.
1965 390 Galaxie 4 Speed
1966 428 Thunderbird
« Reply #344 on: March 03, 2020, 11:03:45 AM »
Look in to the amount of thrust and downforce that zoomie headers on Top Fuel cars can generate. There's some serious forces going on there!
