Author Topic: Guess the horsepower....  (Read 49401 times)
HarleyJack17
Re: Guess the horsepower....
« Reply #45 on: January 24, 2019, 12:10:17 PM »
572 Uncorrected 6,150 RPM
« Last Edit: January 25, 2019, 03:07:19 PM by HarleyJack17 »
FordEver
« Reply #46 on: January 24, 2019, 06:04:09 PM »
615.5 uncorrected
« Reply #47 on: January 24, 2019, 07:19:33 PM »
 Brent,i was wondering if someone hit it right on the number are there any rockerarms involved this time
« Reply #48 on: January 25, 2019, 06:41:42 AM »
Gotta hit the exact number and the peak hp rpm.
6667fan
  • Every Second Counts
« Reply #49 on: January 25, 2019, 12:36:15 PM »
667 uncorrected @6500 rpm
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
mike7570
« Reply #50 on: January 25, 2019, 06:22:27 PM »
Add 6,800rpm to my guess
Reverend Motors
« Reply #51 on: January 27, 2019, 02:31:32 PM »
686 CHP
Sand hauler
« Reply #52 on: January 28, 2019, 09:55:28 PM »
682 corrected hp@ 7200
Bobby-   Carlsbad, NM
WerbyFord
« Reply #53 on: January 29, 2019, 12:52:03 AM »
CORRECTED to STP 60F 29.92 dry sea level, turning water pump only as SAE gross:
2x31 headers
Torq 632 at 4700
Powr 708 at 7000
2.25x31 headers
Torq 632 at 4700
Powr 745 at 7000 +37 wow
UNCORRECTED? Let me hunt down what the un-correction was last time! I agree w Jay/s comments re getting the weather, alt, & air the carb saw going in.
OK it looks like last time the uncorrection factor was about 0.931, SO, uncorrected Gonkulator predictions are
2x31 headers
Torq 589 at 4700
Powr 660 at 7000
2.25 x 31 headers
Torq 589 at 4700
Powr 694 at 7000
What are the header specs?
ok let's go with that, if the CR is really 12.0??? (Turns out I had a good match on the last 392cid at actual CR=11.0!)
Good luck on the dyno!!!
« Last Edit: January 29, 2019, 01:02:10 AM by WerbyFord »
« Reply #54 on: January 29, 2019, 05:38:20 AM »
I’ve pushed back the dyno session until the 8th.
Werb, there was a typo last time on the compression ratio.  No typo this time.
WerbyFord
« Reply #55 on: January 29, 2019, 11:50:18 AM »
Cool! These are fun for everybody, lots of work for you!
Are the headers still 2" primary?
(I know, I found the typo discussion. Sometimes a bad popup design will "act" like a 1.0 CR compression drop, but almost no way to predict that. Glad it was just a typo, the Gonk agrees much better at 11.0 for that 392cid.)
« Reply #56 on: January 29, 2019, 03:59:20 PM »
That 660 looks good for me Werby
Sand hauler
« Reply #57 on: February 03, 2019, 11:34:25 PM »
Make that 682 uncorrected hp @ 7200 instead
Bobby-   Carlsbad, NM
fastf67
« Reply #58 on: February 04, 2019, 07:08:48 AM »
641 @ 6800
Interesting to see the Trick Flow non ported heads stand with the large cam and intake manifold.
countrysquire
    • Houston Vapor Blasting
« Reply #59 on: February 04, 2019, 11:15:12 AM »
651
