Author Topic: Guess the horsepower....  (Read 49557 times)
Re: Guess the horsepower....
« Reply #15 on: January 20, 2019, 09:40:08 AM »
596 hp, uncorrected.
JMO,
paulie
edit:  at 6750 rpm
« Last Edit: February 08, 2019, 02:17:10 PM by plovett »
« Reply #16 on: January 20, 2019, 09:47:52 AM »
Brent, when you go to the dyno try to get some weather information.  I will use that to calculate the correction factor for STP conditions.  I will need barometric pressure shown by the dyno, humidity, temperature of the air going into the engine, and the address of the dyno shop (I can use the address to plug into Google Earth to get an elevation of the dyno shop, and then find a nearby airport to get their barometric pressure, and see if those two values combined match up to the barometric pressure shown by the dyno).
The STP correction factor won't have an inertia factor built in, so if it is a DTS dyno then the STP correction factor will probably be a little lower than the dyno's correction factor, assuming all other values are equal.  My opinion, though, is that the inertia factor isn't really a valid correction, so I like to be able to calculate the STP correction factor, which is purely weather related.
I assume you will post the raw data and the corrected data?
« Reply #17 on: January 20, 2019, 09:52:55 AM »
Sure, I can do that.
69Shakar
« Reply #18 on: January 20, 2019, 12:34:28 PM »
715  uncorrected @6500
« Last Edit: January 25, 2019, 05:37:44 PM by 69Shakar »
sideoilercat
« Reply #19 on: January 20, 2019, 03:38:43 PM »
707
67 Cougar GT 427 M riser side oiler "ALLEY KAT"
70 Cyclone GT 429 CJ
82 Merc Capri 5.0 bought new
Machspeed
« Reply #20 on: January 21, 2019, 01:07:17 PM »
608 hp uncorrected
mn67
« Reply #21 on: January 21, 2019, 02:24:00 PM »
628 uncorrected
1971 Maverick Grabber
hwoods
« Reply #22 on: January 21, 2019, 03:17:49 PM »
716 HP @ 7200 rpm
« Last Edit: January 26, 2019, 08:54:16 PM by hwoods »
« Reply #23 on: January 21, 2019, 05:37:37 PM »
669 hp …. this has a big solid like my 416, Brent are you using non-adjustable rocker arms on this one ??
« Reply #24 on: January 21, 2019, 05:42:44 PM »
No, I had a set of T&D streets earmarked for this build before my rockers came out.
Dumpling
« Reply #25 on: January 21, 2019, 06:42:03 PM »
What kind of fuel will you be using?
« Reply #26 on: January 21, 2019, 06:53:05 PM »
VP/Sunoco 110.
mike7570
« Reply #27 on: January 21, 2019, 07:26:57 PM »
597.8hp
« Reply #28 on: January 21, 2019, 07:43:19 PM »
617 hp @6500, uncorrected  Joe-JDC
« Last Edit: January 27, 2019, 03:24:52 PM by Joe-JDC »
428 GALAXIE
« Reply #29 on: January 22, 2019, 01:08:19 AM »
622 uncorrected.
Mikko
