Author Topic: 390 crankshaft id  (Read 5674 times)
390owner
390 crankshaft id
« on: January 05, 2019, 09:00:21 PM »
Just tore down a fe that is suppose to be a 390  Found 3u on the crankshaft is this a 390 crank?
67428GT500
Re: 390 crankshaft id
« Reply #1 on: January 05, 2019, 10:41:05 PM »
3U- 72-76 390 truck.
chris401
« Reply #2 on: January 06, 2019, 10:23:59 AM »
Look at the crank flange. Half moon cut outs are all 3.3" and 3.5" strokes. 61-63 3.78" strokes had the half moon also. Not sure about the 427 steel crank. Starting with the C4AE-B crank all 3.78" and latter 3.98" cranks had the notch instead of the half moon.
« Reply #3 on: January 06, 2019, 10:39:36 AM »
3U is a 390 crank as said above
CaptCobrajet
« Reply #4 on: January 06, 2019, 10:53:11 AM »
Outside edges of the counterweights on all 390 cranks are beveled.  The 332 and 352/360 cranks all have square corners on the counterweights.  That is the easiest way to tell from across the room.  Sometimes you get lucky.....410/428s also have beveled edges.
Blair Patrick
wsu0702
« Reply #5 on: January 08, 2019, 09:38:02 PM »
Forged steel Ford crankshafts (427 and FT) do not have any cutouts or indexing notches.  Some later cast iron FE crankshafts have a hole instead of a half-moon cutout.  All FE cast iron FE crankshafts have a small rectangular tool indexing notch. Pic courtesy of Wes Adams.
