Author Topic: BT 2x4 intake  (Read 8801 times)
BT 2x4 intake
« on: December 30, 2018, 12:50:05 PM »
So I got a late Christmas present yesterday, received my new BT 2x4 intake and it has the c7 part
number on it which makes it look stock. Very excited since my car is on the verge of a 10 second car and I think it is very streetable. I’m assuming I should be able to get a little more than a tenth out of it. A thanks goes out to Dennis at DSC motorsports everything went very smooth and I got it just when he said I would have it.
67428GT500
Re: BT 2x4 intake
« Reply #1 on: December 30, 2018, 09:26:38 PM »
I have never had an issue with Dennis. He's always been straight up and fair.  I didn't realize that Art had slowed down as much as he has. I was running the BT dual quad as well. It was better made than Ford manifolds and fit better.  I wound up going back to the the C7ZX intake as it's what was correct for the vehcile.
Re: BT 2x4 intake
« Reply #2 on: December 30, 2018, 11:20:17 PM »
Those are nice and very versatile intakes per Jay's book.   What intake do you have on there now?
paulie
Re: BT 2x4 intake
« Reply #3 on: December 31, 2018, 07:18:22 AM »
I have the original low riser intake. I have no complaints about it but was told I should see anywhere from 25-40 horse over the lowriser. So compared to how much money you have to spend to see certain amounts of horsepower an intake swap  is fairly easy as long as nothing has to be cut.
Re: BT 2x4 intake
« Reply #4 on: December 31, 2018, 10:56:29 AM »
That seems reasonable to me.  You mentioned that you are on the verge of having a streetable 10 second car.  That is cool.  Can you tell me the engine and car combination?
thanks,
paulie
67428GT500
Re: BT 2x4 intake
« Reply #5 on: December 31, 2018, 11:25:09 AM »
What heads are on the vehicle?
Re: BT 2x4 intake
« Reply #6 on: December 31, 2018, 12:05:46 PM »
plovett its a 485 with 10.75 compression medium size solid cam 282/288-621-624 112 lobe. Idles at 800/900
in gear. Twin 750 QF carbs with Barrys heads right out of the box. C-6 3000 stall in a 67 fastback 3500 with me in it.
It starts all the time and doesnt overheat. I probably have 1500 miles on it and some track passes.
Re: BT 2x4 intake
« Reply #7 on: December 31, 2018, 01:29:58 PM »
Keith/Plovett:
Some more info.  Need a engine build thread Stangman :P
http://fepower.net/simplemachinesforum/index.php?topic=4340.0;all
« Last Edit: December 31, 2018, 01:32:32 PM by Drew Pojedinec »
Re: BT 2x4 intake
« Reply #8 on: December 31, 2018, 03:05:44 PM »
Thanks Drew
Re: BT 2x4 intake
« Reply #9 on: December 31, 2018, 03:07:03 PM »
On an unrelated note.... Keith, the xp-82 just buzzed my house :P
Re: BT 2x4 intake
« Reply #10 on: December 31, 2018, 03:20:32 PM »
Thanks for the information, guys.
Stangman, can you tell me more about your cam?  Is it a flat tappet or roller? 0.050" duration?  What brand is it?  What lobes are they?  It is obviously working well for you.
thanks,
paulie
Re: BT 2x4 intake
« Reply #11 on: December 31, 2018, 03:56:20 PM »
I will try and get that for you I do have a cam card on barrys other forum that really nobody but me is on.
Re: BT 2x4 intake
« Reply #12 on: December 31, 2018, 04:37:39 PM »
Is it this one?
Re: solid cam 482 stroker
« Reply #2 on: August 28, 2014, 07:31:24 AM »
We've used the below with some good results
SERIAL # F 4449-14   SPEC CARD #  26339014   SPEC CARD INQUIRY BY SERIAL #
 PART #   33-000-5      CAMSHAFT, FB FORD FE 352-428 FT
  CORE     C33-4         CAMSHAFT BLANK, FB FORD 390-428 FT        Special Grin
 GRIND #  FB 6302/ 6408 S112
                              DURATION @ .050 INTAKE      250   ROCKER ARM RAT
  VALVE ADJ INTAKE      .018   DURATION @ .050 EXHAUST     254     INTAKE   1.7
 VALVE ADJ EXHAUST     .020   LOBE LIFT INTAKE            .3530   EXHAUST  1.7
 VALVE LIFT INTAKE     .621   LOBE LIFT EXHAUST           .3550
  VALVE LIFT EXHAUST    .624   LOBE SEPARATION           112.0
 DURATION              .020   INTAKE C/L                108.0
 TAPPET LIFT INTAKE     280   CAM ADVANCE                 4
  TAPPET LIFT EXHAUST    288   HYDRAULIC
 VALVE TIMING          .050   OVERHEAD CAM             N
 VALVE OPEN INTAKE       17   JOURNAL DIAMETER         STD      2.124
  VALVE OPEN EXHAUST      63   RECOMMEND VALVE SPRINGS
 VALVE CLOSED INTAKE     53   DEPARTMENT               R
 VALVE CLOSED EXHAUST    11    SPC INSTR FOR CUSTOMER
                               SURVIVAL MOTORSPORTS
http://fefordtech.com/index.php?topic=130.msg543#msg543
« Last Edit: December 31, 2018, 05:08:36 PM by plovett »
Re: BT 2x4 intake
« Reply #13 on: December 31, 2018, 04:52:47 PM »
That would be a 280/250 TL intake lobe and a 288/254 XTX exhaust lobe.
You have a center oiler without provision for pressurized oil to the lifters?
« Last Edit: December 31, 2018, 05:09:04 PM by plovett »
Re: BT 2x4 intake
« Reply #14 on: December 31, 2018, 06:03:46 PM »
yes thats the one. See im not good enough on the computer to get that and put it over here. There is also another cam in the same post which is alittle bigger. I know that this one is working well but I think the other one might of netted me alittle more horsepower. I do need this motor to last with all the college loans coming in from the kids I cant afford to do another. So I dont mind that the shifting is done relatively low (6200). I dont just unnecessarily beat the crap out of it. I did have the H beams put in so 6200 shouldnt be a problem at all.
