Author Topic: FE Intake Adapter  (Read 495268 times)
XR7
Re: FE Intake Adapter
« Reply #540 on: November 24, 2014, 09:14:41 PM »
That looks good Barry, thanks for posting those pictures and info. John sure can weld aluminum better than anyone I have ever seen.
Also Jay, your BT MR adapter sure came out nice, good job on that, using the HR base to start with (and lots of machining!). Those BT MR port are BIG! Two solutions for the same issue/application, kudos to both of you.
482supersnake
fe66comet
« Reply #542 on: December 10, 2014, 07:52:03 PM »
Blue thunder and Dyre's Blower Service have them already made up.
« Reply #543 on: January 03, 2015, 01:03:25 PM »
Although I often say it to myself, I think I also need to say here that you and your efforts are 'cooler than spats on a duck'!
Faron
« Reply #544 on: January 03, 2015, 03:33:40 PM »
This isn't the first test Ive seen that a Tunnel Ram outperformed the other Street Style Intakes ( Car Craft did it with a Big Block Chevy Years ago ) , BUT what is missing here and the other tests were the street Manners ( kind of like no reason for a Dist recurve for racing ) your tests Start above what most street combos cruise at 3000+, This is where you don't drive a Dyno analogy fits , If You hook a tunnel ram to most combos ( that are truly street cars ) Not Drag Week participants ( no offense meant ) and they will be Dogs,  Lazy under 5mpg under 20mile trip fairground cruisers, 4000+ Stall Converters and gearing really needed for That intake to work well ------  With That said I love your adapter  ;D, I have been looking for a Blower intake for a Cleveland , These Tests are Great , saves the rest of us Dyno Time , Thank You Jay  8)
427Fastback
« Reply #545 on: January 03, 2015, 08:26:13 PM »
Don't know where I was when you dyno'd the 351C manifolds on the adaptor but I missed it...Was the performer port matched or left with the slightly smaller ports...I found the video with the clear valve cover interesting...Not as much oil as I would have thought....Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #546 on: January 03, 2015, 09:11:48 PM »
Glad you like the tests, Faron.  I like them too, because they are so much fun to run ;D  I wish there was a way I could run a dyno test down to 1000 RPM to address issues like low RPM performance of a tunnel ram.  I think there's a lot that can be done with carb tuning to crutch a tunnel ram's performance down low, and I also think that if you convert it to EFI with the injectors down near the ports nearly all the disadvantages at low engine speeds go away.  No way to prove that out on the dyno, though...
« Reply #547 on: January 03, 2015, 09:15:33 PM »
The Performer RPM was NOT port matched, and since the adapter has medium riser ports and the engine has CJ heads, there are two dramatic port mismatches on this setup; one between the adapter and the head at the port floor, and the other at the intake and the adapter at the side and floor of the port.  It amazes me that the Performer RPM did that well with those mismatches in place...
NewFalconOwner
« Reply #548 on: January 03, 2015, 09:45:12 PM »
when my tunnel ram is finished did you want to test it? I could send it out? lol
427Fastback
« Reply #549 on: January 03, 2015, 10:10:33 PM »
Interesting as the torker II port is very close to the port you supply the adaptor with.I think the performer port is about .100 narrower and .400 shorter...The difference in torque has me thinking about using a performer as my car is strictly street driven.....Cory
482supersnake
« Reply #550 on: May 16, 2015, 05:29:58 PM »
I wonder if this would fit on the tunnel port adapter?
http://www.ebay.com/itm/151431234926?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Too bad the ports are rectangular where they meet the heads.
« Reply #551 on: May 16, 2015, 07:39:10 PM »
Hmmm, probably a longshot...
AlanCasida
Trick Flow
« Reply #552 on: May 16, 2015, 08:11:01 PM »
At 37 pages, this has probably been put out there but this might be an interesting setup.
http://www.summitracing.com/parts/tfs-516b0118/overview/make/ford
ToddK
« Reply #553 on: May 16, 2015, 11:03:10 PM »
Jay, any progress updates on the high riser version of the adapter?
482supersnake
« Reply #554 on: May 17, 2015, 12:42:57 AM »
Add an upper like this and you would be good to go.
