Author Topic: 9 inch differential  (Read 6063 times)
9 inch differential
« on: October 07, 2012, 03:26:54 PM »
Long time since i worked on a rear end so
i dont remember. In a 9 inch rearend can you
replace a 2.72-2.82 or around there that i have
with a 4.10 -4.56 or do i have to replace the
differental(Ford Factory LSD) .I remember you have to do it
on brand x differentials.
And who makes high quality streetgears today
i rather pay more and get something thats last
than cheap junk thats start howling like a horny dog
 :o
Re: 9 inch differential
« Reply #1 on: October 07, 2012, 03:48:17 PM »
I've run anything from 2.75s to 4.30s in the same carrier, so I think you can use any ratio.  I would recommend either Richmond or Motive Gear for the gear manufacturer.
« Reply #2 on: October 07, 2012, 04:50:11 PM »
Thanks Jay.
I have the Ford LSD clutch type
differential can it handle a 445
and manual trans
« Last Edit: October 07, 2012, 04:55:40 PM by Heo »
« Reply #3 on: October 07, 2012, 06:36:44 PM »
Sure it can, for a while.  I ran a clutch type in my 489 for years.  As long as tire sizes are the same, you arent doing a lot of burnout box action where one tire may catch traction quickly, and assuming you run a good limited slip additive, they do real well.
Once one of those variables are tweaked, it gets ugly quick.
There are some that have a big hole drilled in the clutch hat, they can crack over time, but generally on the street they all do fine
« Reply #4 on: October 07, 2012, 06:58:30 PM »
Ross is dead on .... the water box at the track can wipe them out quickly
« Reply #5 on: October 08, 2012, 01:03:23 AM »
Ok thanks.
The winter will soon be here so im making
a shopping list :) then the rear only need
a R&P
Can someone recomend a good clutch
without to much pedal preassure so my
wife can drive it.
