Author Topic: expansion plugs in oil galleys  (Read 12940 times)
olman
« on: December 15, 2018, 06:03:23 PM »
I have a C6ME-A  390 block with a 7C29 casting date from DIF . Removed all the expansion plugs from the block to clean the oil passages.  Is it common to find a block that that is not tapped for  1/4 inch pipe plugs on the rear of the block around the cam plug. All 10 galley holes had expansion plugs. Just curious.
440sixpack
Re: expansion plugs in oil galleys
« Reply #1 on: December 15, 2018, 06:12:18 PM »
I'm sure someone knows more about it than me, but I know they don't all come tapped because my machine shop just did it on my 428.
« Reply #2 on: December 15, 2018, 07:10:37 PM »
Very common.
olman
« Reply #3 on: December 15, 2018, 07:25:50 PM »
Barry, I ordered a brass core plug kit from Elgin for the FE blocks and brass plugs are marked 1 3/4" on plugs. In your book you recommend to use 1 49/64. Which manufacturers kit comes with the correct size. I see in your book you have a Pioneer PB-110-B kit but I don't know if it's 1 49/64 or
1 3/4" Did an internet search for them but none show the size of the core plug.
« Reply #4 on: December 15, 2018, 10:41:47 PM »
I like the larger plug.  Those holes do not get smaller in diameter after a few plugs get pounded in and out over the past fifty years....
« Reply #5 on: December 16, 2018, 01:24:28 AM »
So many comments to make, so little time ;D
GJCAT427
« Reply #6 on: December 16, 2018, 05:07:08 AM »
Ah Doug did we skip the meds again!?
« Reply #7 on: December 16, 2018, 08:25:28 AM »
I thin k Doug has taken the opportunity to go off topic.... ;D
« Reply #8 on: December 16, 2018, 11:36:16 AM »
ROFL
C6AE
« Reply #9 on: December 16, 2018, 02:11:15 PM »
Some math can be reassuring here.
A 1/4" dia. press fit plug at 100 psi will have only 5 lbs of pressure pushing against it.
« Reply #10 on: December 16, 2018, 02:27:30 PM »
:o  ;D ;D ;D ;D ;D
« Reply #11 on: December 16, 2018, 06:49:49 PM »
Can one of you engineering types verify this?  For some reason I think its off a bit ... F=P/A?
« Reply #12 on: December 16, 2018, 06:58:15 PM »
Pressure equals force over area.   P=F/A
So F = PA
Force (lbs) = 100 lbs/in^2 * .049 in^2 = 4.9 lbs.
Seems counterintuitive, doesn't it?
« Reply #13 on: December 16, 2018, 06:59:56 PM »
P=F/A
If you solve for F, then F=PA
The area of a .250 circle is only 0.049087385212341 square inches.
If the pressure is 100 psi, then actual force against the surface of the cup should be just under 5 lbs.
F = 100*0.049087385212341
F = 4.9 and change
What I don't know is what the pressure is to push the cup back out, likely not much, but in terms of hydraulic pressure, that does work in the thousands of PSI, the oil galleys aren't pushing that hard and have plenty of leaks enroute as pressure backs up
« Reply #14 on: December 16, 2018, 07:00:43 PM »
Great minds think alike...scary one of them has a business degree :)
