Author Topic: 208 hp 352  (Read 40846 times)
Re: Help with Camshaft selection for a 482 Dual Quad EFI Power Brakes
« Reply #75 on: December 08, 2018, 08:12:36 PM »
I remember the late Joe Sherman saying that with 3 speed automatics it usually improves ET's to short shift from first to second.  Then shift second to third at a higher rpm.  Just rambling...…
paulie
TimeWarpF100
275 hp 352
« Reply #76 on: December 08, 2018, 09:10:12 PM »
275 hp 352
« Last Edit: December 11, 2018, 06:52:22 PM by TimeWarpF100 »
TimeWarpF100
« Reply #77 on: December 08, 2018, 09:27:18 PM »
One more step in case paulie does not have 330'
8.376  660'
Is the Cougar still with me?
« Last Edit: December 08, 2018, 09:30:08 PM by TimeWarpF100 »
« Reply #78 on: December 09, 2018, 06:41:03 PM »
No  660', but 330' is 5.174 seconds.
TimeWarpF100
275 hp 352
« Reply #79 on: December 09, 2018, 07:05:51 PM »
Pretty close!
« Last Edit: December 11, 2018, 06:52:36 PM by TimeWarpF100 »
« Reply #80 on: December 09, 2018, 07:50:14 PM »
1000 ft, 9.876
1/8 mile, 7.708 @ 99.19 mph
1/4 mile, 11.709 @ 123.36 mph.
My best run is 11.49 @ 124 mph, but I didn't see it on my GTECH.  I have a video of that run somewhere, though.
Anyway, my Cougar is likely 500 pounds lighter than your truck and I was using sticky tires.   It is stripped.  No carpet, no sun visors, no headlight doors, manual steering, manual brakes.  Battery in the trunk.  Aluminum heads, intake, water pump, etc.  Light forged aluminum 15" wheels.
paulie
It also idles poorly and get horrible mpg.
TimeWarpF100
275 hp 352
« Reply #81 on: December 09, 2018, 08:03:37 PM »
275 hp 352
« Last Edit: December 11, 2018, 06:52:57 PM by TimeWarpF100 »
TimeWarpF100
275 hp 352
« Reply #82 on: December 09, 2018, 08:08:10 PM »
275 hp 352
« Last Edit: December 11, 2018, 06:53:16 PM by TimeWarpF100 »
« Reply #83 on: December 09, 2018, 08:09:24 PM »
Times were with the GTECH on the street, with wheel spin, and good air.
The Cougar is light.  I haven't weighed it, but I think it weighs less than 3400 lbs.  Maybe 3300 or even less.
13.0 is fast for a 6 cylinder full size truck.  ;)
JMO,
paulie
TimeWarpF100
275 hp 352
« Reply #84 on: December 09, 2018, 08:15:39 PM »
275 hp 352
« Last Edit: December 11, 2018, 06:53:42 PM by TimeWarpF100 »
« Reply #85 on: December 09, 2018, 08:24:49 PM »
JMO,
paulie
Not really buying the " My best run is 11.49 @ 124 mph" spinning tires on street.
The 13.0 run was leaving at a idle if I left with any RPM it would just spin.
That's okay.  :)
« Reply #86 on: December 09, 2018, 08:25:56 PM »
JMO,
paulie
So are you saying your 6 cylinder would just spin, but your 482 doesn't?
« Reply #87 on: December 09, 2018, 08:29:32 PM »
He also asked about wheel spin, from a dead stop I can get in it very hard and no wheel spin! That is a HUGE factor.
This is what I have been trying to figure out
« Reply #88 on: December 09, 2018, 08:59:57 PM »
1000 ft, 9.876
paulie
3500 lbs with driver?
At 3500 lbs and 123 mph 1/4 it would need to be making 500 RWHP.
I think I am making about 550 flywheel hp now.   Not sure, but I did dyno the same engine with a much smaller cam and got 517 flywheel hp.  Like I said I don't know the weight, but it is light for a street car.
TimeWarpF100
275 hp 352
« Reply #89 on: December 09, 2018, 09:07:16 PM »
275 hp 352
« Last Edit: December 11, 2018, 06:54:00 PM by TimeWarpF100 »
