Author Topic: 208 hp 352  (Read 40793 times)
TimeWarpF100
208 hp 352
« on: December 02, 2018, 09:20:19 PM »
208 hp 352
« Last Edit: December 11, 2018, 06:57:36 PM by TimeWarpF100 »
Re: Help with Camshaft selection for a 482 Dual Quad EFI Power Brakes
« Reply #1 on: December 02, 2018, 09:58:42 PM »
What kind of economy are you getting now?
TimeWarpF100
275 hp 390 2v
« Reply #2 on: December 02, 2018, 10:26:49 PM »
275 hp 390 2v
« Last Edit: December 11, 2018, 06:41:11 PM by TimeWarpF100 »
« Reply #3 on: December 02, 2018, 10:27:28 PM »
Don't have all the specs - but a solid cam with 233@.050 in a 482 inch engine should have plenty of vacuum.
Something else might be going on there.
What are you running for timing at idle and what idle speed?
Don't see many 9.5" converters with 2400 stall.  Was that spec'd for a 427 as well?  The bigger cubes will raise the effective stall speed.
« Last Edit: December 02, 2018, 10:29:48 PM by Barry_R »
« Reply #4 on: December 02, 2018, 10:35:55 PM »
I have a solid not roller though,with 234 @ 050, 282, 571 in a 400 and i get 11-12 inch vaccum
Power brakes work just fine
TimeWarpF100
« Reply #5 on: December 02, 2018, 10:53:26 PM »
275 hp 390 2v
« Last Edit: December 11, 2018, 06:41:32 PM by TimeWarpF100 »
« Reply #6 on: December 02, 2018, 10:55:39 PM »
I have two in progress, one EFI and one not, both have very similar issues I have to contend with for the builds.
You said ICL of 104, really need to know LSA to determine overlap (or if cam card says that too, even better)
Vacuum will be affected by overlap, intake valve centerline, and timing (and of course ring seal, valve seal, elevation, air pressure, etc, but those won't change with a cam change)
1. Wider LSA = more vacuum and better mileage
I don't think your lobes are bad, likely fine for what you are using it for, although if it was originally picked for a smaller engine. it's likely tighter LSA than you'd need anyway
If its 108 LSA overlap = 74 degrees
If its 110 LSA overlap = 70 degrees
I'd like to see you in the low 60s, so the same cam ground on a 112 would be 66 degrees, on a 114 would be 62 degrees.
Spreading the centers will be dramatic, idle will mellow out, likely lose a little torque at WOT, (not necessarily at part throttle, it might even feel stronger) but also will likely be more pleasant to drive.
The issue then comes down to how mellow do you want it and what else could you do while you are in there?  Depending on what the cam is now I'd make my decision on 112 or 114.
This won't only help for braking though, it'll also help mileage and make it happier in OD
2. Later intake centerline = slightly less vacuum. However, you can't really go any earlier with that lobe or compression and I don't think you want to add cam
Sticking with the ICL at 104, you are smack on what a normal hot rod should be in a 8.20 DCR range.  So after the 112 or 114 gets you some vacuum you'd still be fine on pump gas, however, you could also rock the cam back a few degrees, and end up with a 106 or 108 ICL.  Seems backwards, but it could gain you a little more on top and give you some room for a little more initial timing and room to play around a bit.  Not to mention, it will likely allow you to get that thing to run on regular gas. FWIW, I can run my 489 EFI FE on anything at all, and only the worst fuel will rattle.  I usually run mid grade or premium, but no fear if 100 miles away and I need gas, anything works.
I don't think you HAVE to run a later ICL but I would if buying a new cam for this application as it has evolved
3. Ignition timing = More gets you more vacuum
Less overlap NEEDS less ignition timing, but with an ICL change, you might be able to add a bit more and get even more vacuum
Lots of overlap wants lots of advance, less overlap needs less, however, by retarding the cam a couple degrees, you get to a DCR of about 8.06, still good, but gives you some room.  Not sure what your curve is now, but I'd like to see a minimum of 20 BTDC as soon as it fires, then have it come all in by about 2700.  Nice thing is you can change it every 15 minutes until you are happy, easy to do electronically. FWIW, my EFI 489 is at 12 degrees for crank and adds 20 when it fires.  This is how Ford does it in the 5.0 Mustangs as well.
So, would like to hear where you are now with the timing curve, idle timing, and LSA but, my initial gut feeling is:
288/292 (same lobes), 112 or 114 LSA, on 106 (or maybe even 108 ICL), and a timing curve that pops a bunch of advance in after it fires.
You could also temporarily try adding some lash, not sure if you lashed it tighter than designed (I almost ALWAYS do)  but less lash should drive up vacuum too, unfortunately it can hammer a solid roller pretty badly when too loose.  Neat test though
One question though, why not hydraulic roller next time around?
FWIW
- on my EFI 489, I run 286/294 110 LSA on 105 (70 degrees overlap), but no power brakes
- on my EFI 461 I am going 280/286 112 LSA on 106 (59 degrees overlap) with power brakes
- on the carbed 461 with power brakes we are doing, I am trying to make a little more power, and likely going 288/292 114 LSA on 106 (62 degrees of overlap) or a single pattern 292/292 114 LSA on 106 (64 degrees of overlap)
Hope this helps, if you can give more info on the things I asked above, will dive in deeper after work
« Reply #7 on: December 02, 2018, 10:59:28 PM »
Just saw the updated posts after I sent mine in.
First thing I would do is see if the FITECH allows you to kick in timing after start.  I'd love to see you sitting at 20-22 at idle with EFI, then let the idle air control motor adjust idle speed to where you want it, don't use timing to set idle speed.  You might get close enough
Still would like to hear LSA, because regardless, overlap makes for a dirty chamber at idle, timing will help, maybe a lot, but overlap is what it is, and at idle, the sound we love is the engine not running very efficently.
Additionally, I have been meaning to get to know FITECH software to help some local guys out here, let me see what i can download tomorrow and I may be able to help with a timing curve
« Last Edit: December 02, 2018, 11:00:59 PM by My427stang »
TimeWarpF100
275 hp 390 2v
« Reply #8 on: December 02, 2018, 11:06:25 PM »
275 hp 390 2v
« Last Edit: December 11, 2018, 06:41:52 PM by TimeWarpF100 »
« Reply #9 on: December 02, 2018, 11:18:30 PM »
Looking back at what I have in my Dyno Program it shows Intake Centerline 104 Exhaust Centerline 108
Lobe CL 106.0
Valve Overlap 44.0
Cam Accel Rating 4.22
I will get a pic of cam card that came with cam
I'll check back in in the AM, but if it's 106 LSA, that's really a cam for a small CID carb'd engine IMHO. That'd be 78 degrees of overlap.  Additionally, that oxygen sensor won't be too happy as it's getting cooled down by a lot of raw fuel and making bad recommendations.
Going 112 LSA with the lobes you have, or even a bit more lobe at 114 could completely change that truck's behavior.
BTW, Spreading the centers doesn't make them sound that wimpy either, here is my 10:1 445 with only 58 degrees of overlap, 280/230 112 LSA solids on 106, dual plane intake and carb, and 12 degrees of initial.  That was idling around 850, not EFI, but a smaller cam than I'd recommend for you and still has some lope.  It was a REAL strong 445, but I had block problems, so it's coming back as an EFI 461
https://youtu.be/Uf3D5c9ZZfs
Here's the 489 with EFI and 70 degrees of overlap and the 22 degrees of timing at idle.  It gets about 16-18 mpg when driving easy with 4.11s and a TKO-600 with a .64 (nowhere near that when I am hammering it
https://youtu.be/AtTEvZ2uQmA
« Last Edit: December 02, 2018, 11:23:46 PM by My427stang »
TimeWarpF100
275 hp 390 2v
« Reply #10 on: December 02, 2018, 11:24:22 PM »
275 hp 390 2v
« Last Edit: December 11, 2018, 06:42:13 PM by TimeWarpF100 »
TimeWarpF100
275 hp 390 2v
« Reply #11 on: December 02, 2018, 11:33:45 PM »
275 hp 390 2
« Last Edit: December 11, 2018, 06:42:28 PM by TimeWarpF100 »
« Reply #12 on: December 03, 2018, 12:01:50 AM »
Let me tell you, I saw the cam card on my phone and got out of bed to go on the computer
In my experience, that cam is decent for a high compression carb'd 390 or maybe a 427 but not one that would rev too high.  it really has no business in that build, and I am the guy who doesn't think cams are that critical for EFI if you take the time to tune around them
I don't even think it's a decent cam for a carbed 482, I think with even with carbs they should have spread the centers and given you more lobe.
It sucks, but that truck will be faster, nicer and better on fuel with cam that matches.  Try getting some initial in it, if you haven't figured out the FITECH curve, I'll look at it over the next few days and report back, but there are some sharp cats on here running FITECH that may be able to chime in on how to get some initial in there and keep idle where you want i
I'd love to stay up all night but its 11PM and I need to be up at 5AM.  Happy to chat here, by PM, or by email, that truck will be so much happier when cammed right and then you can tune and really get to see what EFI can do for you.
I still think you need to get overlap way down, but also think you could use more .050 too.  Same boat as that carb'd 461 I am doing. Spread the centers so you can get some lobe in there
Thanks for getting back so quickly
« Reply #13 on: December 03, 2018, 06:22:22 AM »
Found the cam card!  Going from memory not so good . .
Holy cow.  78° of overlap and that's supposed to be optimal for EFI?
I understand that he was trying to grind you a solid roller that would live easily on the street, but the LSA should have been much, much wider and the advertised durations a little lower.
That cam should have been a hydraulic roller.  For the rpms that you'll be turning, it would eliminate all risk.
« Last Edit: December 03, 2018, 06:36:18 AM by blykins »
« Reply #14 on: December 03, 2018, 07:03:29 AM »
So, looking at your combo, and starting with gearing
You have an 8.6:1 1st gear ratio, although the loose converter helps that a little,. High gear is going to be 3.50 or in OD 2.73
If I was writing the checks, I'd love to see a tighter converter and more gear, but it is what it is.  If that's an option you may want to consider and go with a 3.89 or 3.91, that would help around town more than on the highway, because with the loose converter and ending up at 3.04:1 or it won't really contribute to highway mileage, but both together would make the truck happier.  Not required but something to think about later
Second, the TW isn't doing you any favors, but I am not afraid of too much intake if you are pulling vacuum, just remember, your FITech is a precise electronic carb, so at low RPM that intake isn't going to be as happy as a med riser dual plane would have.  Fuel won't be happy to hang in suspension when the air isn't flowing and that's a big intake.  Not a necessity to change an intake but it's pushing back at you a little.
I do have to ask though, where are you getting the water temp info for the FITech?
Just want to make sure that the water temp sensor is in the old gauge sender hole, it needs real clean data, I usually add a second bung so I can run a gauge, if you haven't and need a gauge, move that gauge to the thermostat housing, and be sure the FITech coolant temp sensor is on the intake
Now, Barry's heads are good, you don't need any significant split to get that motor to breathe, so I would likely do a single pattern cam, and I will warn you, I REALLY think this motor is a natural for a hydraulic roller, but delivering as requested first :)
For solids, I would run a single pattern cam designed to build vacuum and be happy in OD.  It won't have the thumpy idle and will likely sound somewhere between my truck and the Mustang in my videos.
There are many ways to skin the cat, however my initial WAG would be
Comp lobe 6057 lobes, intake and exhaust, 282 adv/242 @ .050, on 106 with an LSA of 112.  You'll match or gain power, add about 200 RPM at the HP peak, and  likely pull quite a bit more vacuum going from 78 degrees overlap to 58.
Just giving you an initial WAG because I am off to work, don't spend money yet, we can get closer, but that is the type of cam that would make the EFI happy, make the truck less sloppy down low, and pull harder on the intake at part throttle.  Combine that with some tuning, it'd likely make it dramatically more fun.
We can even go milder depending how close you want it to the Ecoboost curve, but likely you'd want a converter swap at some point.
« Last Edit: December 03, 2018, 07:07:49 AM by My427stang »
