Author Topic: Rear main sealing  (Read 3777 times)
allrightmike
Rear main sealing
« on: November 26, 2018, 09:57:14 AM »
   I have been told by people in the seal business that a small percentage of rear main lip seal conversion leaks are caused by variance in the seal cavity.  It is said that since a rope style seal was to be used the tolerance for the cavity was not held particularly close as it would not matter with the rope seal. I believe the number was around 8%. Does this theory hold water,or oil,sorry.
Mike.
'60 Starliner 427 4speed.
440sixpack
Re: Rear main sealing
« Reply #1 on: November 28, 2018, 11:25:00 PM »
That makes sense.   in my Pontiac tripower I converted it to a lip seal but the seal was made specifically for that purpose.   is there maybe such a seal for an FE ?
chris_r
« Reply #2 on: December 01, 2018, 08:25:15 PM »
You can get rope or rubber seals for the FE
GJCAT427
« Reply #3 on: December 02, 2018, 10:01:22 AM »
I get the Felpro seal kits. Trick I use is to stager the seals so that they don`t line up with the parting line and a very small dab of sealer on the ends. Haven't had a leak yet.
