Author Topic: 428 CJ Parts  (Read 5313 times)
The Real McCoy
428 CJ Parts
« on: November 13, 2018, 03:03:10 PM »
I have some 428 parts that I would like to sell.  All parts are plus freight from 56016.  If it would help, I am making a trip from southern Minnesota to Harrisburg, PA at Christmas with the possibility of delivering some of the heavy stuff.
C8OE 9425-C 428 CJ Intake Manifold, Date Code 8G29, Manifold is extremely clean and in excellent condition. Currently is painted black, I was going to use it in my 63 Galaxie but ended up going the 2 x 4 route.  (And it weighs 81 pounds before packaging.)  $375 SOLD
428 Crankshaft 1U crankshaft, Rod journals @ .010, Main journals @ .010.  Will at least need to be polished.  $275  SOLD
428 flywheel for C6 Transmission with spacer ring for flywheel bolts.  (Fly wheel bolts are not included)  Excellent condition, $75  SOLD
C9ZE-6582-B, 428 CJ Valve Cover.  Note there is only one of them.  Cast Aluminum with the ribs in it.  I think it is for the road side based on a decal for idle speed and the oil cap opening (no grommet). $45  SOLD
428 CJ Metal Vacuum Line and both manifold fittings for PCV, Power Brakes, etc. $100  SOLD
Set of 8, 428 Std. pistons.  These come out of a 428 CJ core that I turned into a 462.  7 of the pistons are TRW stamped L2245 STD on the piston face, the 8th piston appears to be an OEM piston with ”428” cast vertically adjacent to the piston pin boss.  All the pistons appear to be in relatively good condition and appear to have very little time on them.  $125
428 CJ C8AE A1 Crankshaft Damper and C8AE-6312-D 3 Groove Crankshaft Pulley assembly.  These were pretty badly rusted when I got them so I did blast and paint them.  The damper still has some pitting making the timing marks hard to see so it will probably need a timing tape installed. They will work fine and the rubber on the damper looks to be in very good condition.  I would split these up if someone wanted.  $100
Vintage Mickey Thompson FE Valve Cover Set, These have a black Crinkle finish with some of the paint coming off.  Functionally they are fine but will take some work to make them look good again.  $100
« Last Edit: December 24, 2018, 08:45:50 AM by The Real McCoy »
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
FERoadster
Re: 428 CJ Parts
« Reply #1 on: November 13, 2018, 04:17:19 PM »
I'll take the CJ valvecover. Please calc. shipping to Brookings Oregon Zipcode 97415
Richard
The Real McCoy
Re: 428 CJ Parts
« Reply #2 on: November 13, 2018, 04:52:38 PM »
Thanks Richard. It will probably be Thursday before I get a chance to check out shipping cost. I will PM you when I have some information.
63 1/2 Galaxie 500
FERoadster
Re: 428 CJ Parts
« Reply #3 on: November 13, 2018, 10:06:01 PM »
Thanks ! The reason I can buy just one is about 5 years ago I purchased 5 CJ VC's that were basically ruined by someone cutting breather holes in the sides and capping the fillers.
I've rehabbed  a few of them but others are beyond repair. I already had 2 pristine CJ covers but maybe with TIG welding (and your one) I can get 2 more nice sets.
Richard  >>> Movin/on
The Real McCoy
Re: 428 CJ Parts
« Reply #4 on: November 15, 2018, 11:14:27 AM »
Richard
Give me a call at ninefive2 9onethree threethree17
Thanks
63 1/2 Galaxie 500
The Real McCoy
Re: 428 CJ Parts
« Reply #5 on: December 11, 2018, 07:12:15 PM »
Bump
63 1/2 Galaxie 500
