Author Topic: 445 dyno  (Read 35019 times)
mn67
445 dyno
« on: November 12, 2018, 10:02:58 AM »
Performance Summary:
      Cubic Inches:445          Dyno brand: Super Flow 901
      Power Adder:                Where dynoed:FE Power
      Peak Horsepower:493 @ 5400
      Peak Torque: 515 @4000
Horsepower and Torque Curves:
Engine Specifications:
 D3TE Mirror 105, 4.080 bore
   Crankshaft : Scat, cast, 4.25
   Connecting Rods :Scat I-beam 6.700, ARP bolts
   Piston brand,  Race-Tech, 11cc dish, 10.5 cr
   Main Bearings, Rod Bearings, Cam Bearings brand and size: FM, FM, Durabond
   Piston rings brand, size, other notes: Mahle 1.5,1.5,3
   Oil Pump, pickup, and drive: Melling HV
   Oil pan, windage tray, oil filter adapter: Morosso T-pan, none, Ford
   Camshaft: (adv and @.050") Comp Hyd roller, ADV 291/303, .602/.574, -@.050 235/241
   Lifters brand, type: Howard Hyd roller
   Timing chain and timing cover: Roush
   Cylinder heads : Survival Motorsports street/strip ported
      Intake               Exhaust
      .100               .100
      .200   176       .200 130
      .300   216       .300 152
      .400   270       .400 187
      .500   296       .500 216
      .600   313       .600 229
      .650   317       .650 229
   Flow bench used, location: T.E.S Bloomington MN
   Intake valve brand, head size, stem size: 2.20, 11/32
   Exhaust valve brand, head size, stem size: 1.68  11/32
   Valve springs brand, part number, specs: Comp conical, 158# seat, 382# open
   Retainers and locks brand, part number, specs: Comp
   Rocker arm brand, type (adjustable or non-adj), material, ratio, Harland Sharp, 1.67, adjustable, Aluminum
   Rocker shafts and stands, brand, material: Harland Sharp
   Pushrods brand, type, length:Trend, 3/8, ball cup, 8.247
   Valve covers, brand, type: Pentroof Blue Thunder
   Distributor brand, advance curve information: Duraspark (By Faron Rhoads)
   Harmonic balancer brand:Powerbond SS
   Water pump brand, type (mechanical or electric): CVR 55 GPH electric FEpower adapters
   Intake manifold brand, material, porting information: Blue Thunder dual plane 4v, port matched to heads
   Carburetor(s) brand, type QF HR780VS
   Exhaust manifolds or headers brand, type: Hooker race headers
« Last Edit: November 12, 2018, 10:11:24 AM by mn67 »
1971 Maverick Grabber
rcodecj
Re: 445 dyno
« Reply #1 on: November 12, 2018, 11:57:19 AM »
Nice!
Re: 445 dyno
« Reply #2 on: November 12, 2018, 05:55:00 PM »
Very nice. What is she goin in.
mn67
Re: 445 dyno
« Reply #3 on: November 12, 2018, 06:07:33 PM »
Stangman, it is going in a 1971 Maverick Grabber, pretty light car.
Re: 445 dyno
« Reply #4 on: November 12, 2018, 07:12:35 PM »
Wow that little thing is gonna scoot along pretty good. Can’t wait to see the finished  product
mn67
Re: 445 dyno
« Reply #5 on: November 12, 2018, 07:25:57 PM »
It is a tight fit
WerbyFord
Re: 445 dyno
« Reply #6 on: November 12, 2018, 08:58:49 PM »
Cool combo. Was the dyno with open headers or into mufflers?
mn67
Re: 445 dyno
« Reply #7 on: November 13, 2018, 06:46:12 AM »
Werby, good question, I am not positive but I am pretty sure it was into mufflers. I will have to ask.
WerbyFord
Re: 445 dyno
« Reply #8 on: November 13, 2018, 03:10:21 PM »
That was my guess.
See if you can find out diameters, lengths, muffler size/types for the exhaust, it makes a big difference at that power level!
Re: 445 dyno
« Reply #9 on: November 13, 2018, 04:50:40 PM »
If it was on Jay's dyno, I believe he has a bit of an aside in his book to talk about the exhaust setup of his dyno.
mn67
Re: 445 dyno
« Reply #10 on: November 13, 2018, 04:52:25 PM »
I will look at the book when I get a chance tonight.
Re: 445 dyno
« Reply #11 on: November 13, 2018, 05:08:00 PM »
I think it was a chicken house full of used tires.  ;D
Re: 445 dyno
« Reply #12 on: November 13, 2018, 06:11:56 PM »
That was a chicken 'coop', not a house. A chicken 'house' would probably raise his taxes and cause the zoning commision to investigate his 'rental' properties ;)
mn67
Re: 445 dyno
« Reply #13 on: November 13, 2018, 07:24:53 PM »
4 Dynomax Two are 2-1/2" in and out, and the other two are 3" in and out.
WerbyFord
Re: 445 dyno
« Reply #14 on: November 13, 2018, 08:42:20 PM »
Thanks that makes sense.
In any case, at least you have plenty of wide open space there in MN. And will need it - even Jay's dyno exhaust was probably costing you 15hp or more the way I figure it. 15hp out of 500 isn't much though, maybe 1mph trap speed.
Thanks for posting, another data set for the Gonkulator!
