Author Topic: FE in a 77 F150 4X4  (Read 5339 times)
dmazz
FE in a 77 F150 4X4
« on: September 27, 2018, 08:06:40 AM »
We are planning to swap engines in a 77 F 150 4x4 435 4 speed, the truck currently has a 302, the 390 we want to put in the truck came out of my 66 Fairlane. Are the cross members different from 76 to 77, will we need a different oil pan for a 4x4. All input and suggestions will help, thank you.
66 Fairlane GT 427 4 speed Black
67 Mustang Coupe K Code Vintage Burgandy
93 Lightning Black
FrozenMerc
Re: FE in a 77 F150 4X4
« Reply #1 on: October 16, 2018, 12:59:19 PM »
76 and 77 model years were virtually identical.  The crossmembers should be the same.  My '76 F-250 has a 390 in it.  Great motor for that truck.
« Reply #2 on: October 17, 2018, 05:55:08 AM »
There should be no crossmember in the mix on a 4x4.  You just need the correct frame perches and mounts that come from the frame rails
Yes you will need a 4x4 oil pan and pickup, they are rear sump.  A front sump would be directly over the axle
FERoadster
« Reply #3 on: October 18, 2018, 10:40:50 AM »
Remember that the 1976 FE 4X4 had the angled oil filter adapter and they are kind of hard to find. Not sure if a 77 would have the same issue. I haven't looked to see if the PU adapter or car adapter would fit. I don't have a 1976 4X4 PU to check the fitment.
Richard
« Last Edit: October 18, 2018, 11:39:50 PM by FERoadster »
