Author Topic: .040 390 pistons  (Read 12712 times)
George vega
.040 390 pistons
« on: September 14, 2018, 11:50:20 AM »
Looking for suggestions on .040 forged pistons. Would like to keep the compression where I can run pump gas or mix half and half. Thanks
68 Mustang Cobra Jet tribute Race Car
George vega
Re: .040 390 pistons
« Reply #1 on: September 14, 2018, 03:59:23 PM »
Found some L2291 with coated sides and rings for about 350. Good for 6500+ rpm and 150 shot of nitrous.
« Reply #2 on: September 14, 2018, 04:44:38 PM »
Thats what i run, on pumpgas had seen 6500 a few times
George vega
« Reply #3 on: September 14, 2018, 05:25:40 PM »
The price is good and the only time my car goes over 6500 is when running 1/4 mile. I'll mention them to my machinist and see what he thinks. Thanks
« Reply #4 on: September 14, 2018, 05:48:36 PM »
As i se it, yes its a "outdated " design with outdated ringpack
but it will do a good job as a street piston longevity and all that
for that price
George vega
« Reply #5 on: September 14, 2018, 06:08:15 PM »
I plan on backing from just racing to a strip and strip mode. So im trying to put more reliability in the engine for street use. That's  why I'm thinking of going with these pistons. Yes, they are heavier and as you stated, out dated ring sizes but they're good enough for what I want to do. Thanks
« Reply #6 on: September 14, 2018, 07:53:07 PM »
I like the L2291s, they make a nice little 390 if you don't have serious valve events or valve sizes.  Not a lot of room in the pockets compared to a modern piston.
They do fine though and with a little cut to the deck end up around .004 below
« Reply #7 on: September 15, 2018, 03:01:14 AM »
I cut my deck to zero 10.155 i think it was. The streetmaster
intake lined up perfect with 040 headgasket and uncut C4-G
Heads
George vega
« Reply #8 on: September 15, 2018, 08:56:05 AM »
The deck was cut .020. I do have larger valves but he will modify the pistons to fit and cut my intake for proper fitment if necessary. I'm using my 428 eagle crank and rods. It comes out to about 421 ci I think.
« Reply #9 on: September 15, 2018, 10:02:46 AM »
So, I may have misunderstood the build, but
10.170 block cut .020 = 10.150
Crank (3.98/2)+6.49+1.776=10.256
Those will be .106 above deck.   Are you sure you have the right piston part number?
George vega
« Reply #10 on: September 15, 2018, 11:09:27 AM »
I may have to use 410 pistons or custom made. Just to clear info on the block. It's  a mirror 105 block, bored .040, and .020 taken off the head surface. Using 428 crank and rods. Yes the pin needs to be lower and maybe cut the top of the pistons. Thanks
George vega
« Reply #11 on: September 15, 2018, 04:32:27 PM »
I meant raised the pin to lower the piston.
« Reply #12 on: September 15, 2018, 04:42:06 PM »
Give Brent a call, he can hook you up and there won't be any guess work.
Measure your bore, calculate what you need for compression and pin height with him and no labor cutting for valves.  I think you'd be surprised at the difference in cost in the end, and all you do is bolt it together no cutting parts and hope they are strong enough, no digging into a thinner crown for valve reliefs, etc
« Last Edit: September 16, 2018, 06:46:21 AM by My427stang »
winr1
« Reply #13 on: September 16, 2018, 03:34:42 AM »
I have a set of those pistons
They are not light as hi dollar pistons but lighter than factory
Mine, with a 3.78 crank are .013 in the hole
Gonna check piston to valve clearance with piston at TDC
See what I come up with subtracting .087 shaved off the top of the piston
This is to see what clearance I would have using a 3.98 crank
EDIT:  the top of the piston to the 1st ring land is .370 IIRC
Ricky.
« Last Edit: September 16, 2018, 03:36:59 AM by winr1 »
CaptCobrajet
« Reply #14 on: September 16, 2018, 09:09:52 AM »
I think there is a Mahle Powerpak for that combo.  It's a nice ring pack, coated, etc..  Very good pistons.
Blair Patrick
