Author Topic: First road trip analysis for the Mustang (update 8/21/18)  (Read 10437 times)
AlanCasida
« on: August 18, 2018, 06:18:36 PM »
 took the Mustang for about a 30 mile road trip this afternoon and although it ran good I do see a problem...Drag Week wise. Keep in mind that is about 85 here today and overcast. Going down the road and driving through town the water temp hovered around 195-200...not too bad. When I got back home I purposely let it set idling for about 5 mins and the temp was up over 220 and when I pulled it into the shop it went up to around 230. Next I let it set for another 5 mins(engine off) to let the starter soak up some heat. It did start right up. I'm not sure what will happen when it might be 95 and sunny though. The issue I see for me is if I get caught in some monster traffic jam(like in Indianapolis year before last) my car might have a meltdown at the most inopportune moment. I think it will be a sweat box too and I will definitely need ear plugs but those I can deal with.
« Last Edit: August 21, 2018, 07:32:20 PM by AlanCasida »
Re: First road trip analysis for the Mustang
« Reply #1 on: August 18, 2018, 07:07:48 PM »
Alan, just curious if you have an electric fan on it? I can't remember if you mentioned that before or not. An old trick of raising the back of the hood may also help a bit. Any way to let some of that hot air out.
The engine getting warm while sitting still reminds me of the story of the guy who went to the doctor and complained about his arm hurting when he raised it straight up, so the doctor told him "don't raise it straight up" ;)
« Reply #2 on: August 18, 2018, 08:27:13 PM »
Alan, what temperature thermostat have you got in the engine?
AlanCasida
« Reply #3 on: August 18, 2018, 08:38:42 PM »
I have an engine driven fan with a good shroud and a 180 deg thermostat. I have a Griffin cross flow radiator that has two 1 1/2" cores.  I have blocked the waterpump bypass that connects to the intake manifold and drilled seven 1/8" holes in the stat to let water pass through until it opens. I have my sender mounted right before the thermostat housing on the intake adapter and I noticed going down the highway the temp would sometimes fluctuate fairly fast between 190 & 200. It makes me wonder if it is always coming in full contact with the water and maybe giving me an erroneous reading. Also it is an Autometer mechanical gauge.
« Last Edit: August 18, 2018, 09:09:25 PM by AlanCasida »
« Reply #4 on: August 19, 2018, 04:24:15 PM »
If that temp gauge is moving back and forth rapidly at times, you probably have some air left in the system.  With that thermostat and that radiator, going down the road you ought to be right at 180 (assuming the thermostat is working correctly).  Check the fluid level, with the engine running, and see if it drops down a bunch when you rev it up.
« Reply #5 on: August 19, 2018, 04:49:01 PM »
Type of fan matters too, once you get the gauge stable, fixed fans can move a lot of air
AlanCasida
« Reply #6 on: August 19, 2018, 05:45:14 PM »
I checked it and it looked ok but I didn't rev it up. I'll double check that. It wasn't filled to the top but I've always been told to leave some room for expansion. I could fill it up closer to the top and see what happens. It was raining all day today so I didn't get a chance to drive it. I did pull the t-stat housing just to be sure I had it in the right direction(it was) and I've spent the rest of my time working on my trailer.
« Reply #7 on: August 19, 2018, 05:54:27 PM »
Assuming it's a side tank, they don't need nearly the room the old top tank design needed.  Fill it up, it'll find it's own level :)
« Reply #8 on: August 19, 2018, 08:55:11 PM »
I've always filled my stuff up to within a 1/2" of the bottom of the neck and never had expansion issues, including in the Mach. I would have checked that thermostat in a pot of water on the stove, with a thermometer. It wouldn't be the first time I've seen one act weird by not opening up at rated temp, or not open up all the way. Although, like Jay said, air hitting the probe is the only reason I could see the temp fluctuating rapidly on the gauge. Why did you block the bypass?
AlanCasida
« Reply #9 on: August 19, 2018, 10:20:59 PM »
It's something I tried back when I had my '89 Mustang with a 460 in it trying to get it to stay cool. l I don't know if it made any difference for sure but I didn't like the idea of hot water circulating right back into the engine. Although if the thermostat is open it probably just goes out to the radiator anyway.
« Last Edit: August 19, 2018, 10:23:22 PM by AlanCasida »
AlanCasida
« Reply #10 on: August 21, 2018, 07:31:24 PM »
Ok I got a new t-stat, moved the temp sensor to the waterpump bypass port on the intake, jacked the front of the car as high as I could get with I refilled the radiator and it still bounces between 190-200 driving down the highway 60mph @ 2600 rpm. This was within 4 miles. It's 78 deg out so with the monster radiator I have it shouldn't run that hot...that soon. I was thinking about this today and this may be a symptom of a larger issue. I dug out the sonic map of my block and it is pretty thin...especially on the non thrust sides. I don't know how thin is too thin but my cooling system may be doing all it can. I don't think I had this issue when I had it in my Galaxie but I had an electric gauge in it that may have responded slower and I was running about 9:1 compression where as now with my TF heads and thin head gaskets I am running right at 11:1. I have included a copy of my sonic map to see what you guys think. Keep in mind this is something I drew out at work over the phone.  ::) Also #6 cylinder had a sleeve in it that gave them an erroneous reading(it was replaced too) and this was taken before it was bored to 4.25". It was standard.
« Last Edit: August 21, 2018, 07:33:52 PM by AlanCasida »
Re: First road trip analysis for the Mustang (update 8/21/18)
« Reply #11 on: August 21, 2018, 08:15:40 PM »
Hmmm, I've got one thinner than that and it doesn't get hot.  I'm thinking its something else.  A couple things you might try is to put some race gas in it and see if that cools it down (this would indicate a detonation issue), or swap water pumps; sometimes the impellers can come loose and you won't know it.  You have a spring in the lower radiator hose so that it won't collapse under suction, I assume?
AlanCasida
« Reply #12 on: August 21, 2018, 08:21:57 PM »
Yes I do have spring in the lower hose. An odd thing I noticed was it will try to collapse the upper hose when I rev it up. I've never seen anything of mine do that before. That is, it will do that until it gets really warm and the hose has a lot of pressure on it.
« Reply #13 on: August 21, 2018, 08:55:26 PM »
Usually when the upper hose collapses, it is from a bad radiator cap not allowing it to vent(air, or coolant if recirculating system).
The bypass is a good idea I think if you are not running a heater core. Any time there is a heater core, I like to block the water pump/intake bypass because I don't have to fiddle with that stupid little hose and the heater core acts as a bypass anyway.
« Last Edit: August 21, 2018, 08:58:34 PM by Nightmist66 »
TimeWarpF100
« Reply #14 on: August 21, 2018, 11:36:56 PM »
Have you ever tried Redline Water Wetter? I have found it really works. Not that is a CURE but worth a try.  I have never had good luck cooling with thin cylinders.
