Author Topic: I'd like valve spring recommendations for my 390 build  (Read 11770 times)
dmann
« on: August 10, 2018, 04:47:48 PM »
Hello,  I'm completely new to FE engines.  I have a 1971 F250 with a 390 engine, which was rebuilt prior to me purchasing the truck.  I decided to do some upgrades before I take the truck on some family vacations towing a 24 foot camper.  I did find that the truck has a 3.5 something rear gear (can't remember how I found it, I think I read a tag with the info) and a C6 transmission.  I want to save this truck and pass it down to my son, so I decided that I could spend some money on it to jazz it up a little.  I purchased the new Edelbrock Pro-Flo 4 EFI system, headers, Hughes XTM towing torque converter, and some misc upgrades like a classic auto air AC system.  I decided to pull the front end off and yank the motor so that I could clean up the frame a bit and handle some rust on the inner fenders and install the torque converter.
The previous owner told me that an "RV cam" was installed but there are no specs at all.  Since I'm going to have the engine out I thought I'd upgrade the cam...and a friend of mine at work is retrofitting an LS into his old Chevy truck.  He was getting a new roller cam and so I thought I would also.  I purchased a cam and lifter kit from the Lunati website.  The cam is a small roller cam and the specs are:
Advertised Duration (Int/Exh): 262/270
Duration @ .050 (Int/Exh): 211/219
Gross Valve Lift (Int/Exh): .559/.559
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5600
Includes: Cam & Lifters (#72336-16)
Part Number: 20330710LK
I've done cam swaps before this in other engines (Chevy) but they were small flat tappet cams.  After the purchase I realized that I didn't know JACK about FE engines and that I had no business buying a cam when I don't know anything about FE valve train.  I just purchased two books: Ford FE Engines: How to Rebuild and How to Build Max-Performance Ford FE Engines (Performance How-To).  I'm going to read those books and see if I can figure out what parts I need to buy or what machine work is needed to run this cam.
I'd like to get in contact with some folks who know FEs and get opinions on where I should go next.  I tried to call Survival but I didn't have any luck getting through (I'm in PST timezone though, so maybe I need to call earlier).
Could anyone offer a kind word of advice to someone who needs training wheels with FE engines?
At least I didn't commit the biggest sin and stick and LS in it :-)
Best Regards,
Dan
Re: I'd like valve spring recommendations for my 390 build
« Reply #1 on: August 10, 2018, 05:18:43 PM »
Do you know your install height?
manofmerc
« Reply #2 on: August 13, 2018, 03:40:57 AM »
I would contact lunati its their camshaft they will know what springs to use .Get new retainers and keepers also .When specing the retainers don't forget your valves are 3/8" .And like Brent said knowing the valvespring installed height would be useful . 8)
« Reply #3 on: August 13, 2018, 08:12:31 AM »
Stick with Brent, he does a ton of these and Manomerc has the right idea too, but I put less stock in the companies, although Lunati is good, you need to get them on the right track
Some comments:
1 - You will need both retainers and springs as you likely have the heavy two piece retainers now.  Those retainers also don't leave much room for a seal and you are significantly adding lift at .560 or so
2 - Time to replace your valve seals with a good positively located Viton (not white Teflon).  The EFI will be using an O2 sensor and you want to keep the exhaust as clean as you can.
3 - Since you have the engine out and intake off, I would consider pulling the heads and having the guides checked at least.
4 - Good cam choice for the use.  BTW, you are likely at 1.81 installed height stock, but best to measure
5 - Easy to start spending your money here, but you are also pretty good at it yourself :)  When you get in there, you may find this is a low compression truck 390, you can tell by the pistons being way below deck at TDC.  If it is, you may want to consider going whole hog and rebuilding it.  It isn't a must-do, but with likely 3 grand of parts now, may as well do it right.  Either a nice zero deck 390, 410, or even a 445.  Sounds crazy, but if you are at 8:1 compression and .100 deck clearance, you'll be happy after you bite the bullet compared to where you would be
dmann
« Reply #4 on: August 13, 2018, 10:29:54 PM »
I just pulled my heads but I haven't disassembled them yet, and I also just checked the pistons and they are around .130 to .140 thousandths below the deck at TDC.  They are some sort of replacement piston from the looks of them, they have a mark that appears to show they are .020 oversized.
« Reply #5 on: August 14, 2018, 07:19:14 AM »
So likely a truck 390 or maybe a 360, better measure stroke.
If it has the truck 390 pistons, you can swap a 428 crank in it and make a 410 (assuming the parts are good and likely have someone cut the ridge)
If it's a 360, you can get a 390 crank and rods and it will be a nice little zero deck 390 at about 9.25:1
FElony
« Reply #6 on: August 14, 2018, 01:58:05 PM »
Or you can put a turbo on it.
dmann
« Reply #7 on: August 14, 2018, 03:30:07 PM »
Well I ordered some of those Trick Flow heads, I guess we'll see where that gets me.  I won't be doing the stroker this year but perhaps next year.  At this point I just hope for something a little bit better than what I had.  I guess I'll need to get it assembled figure out what pushrods I'll need.  I ordered that compcams roller rocker setup also so I should have some degree of adjustability.  I really want to get this thing back on the road quickly...I miss driving it.  I'll post back with updates about what worked and what failed.
« Reply #8 on: August 14, 2018, 04:04:18 PM »
Depending which pistons you have and which head gasket you pick, you could be under 8:1 compression.
On the good side it'll run on any fuel you put in there :)
dmann
« Reply #9 on: August 14, 2018, 04:17:52 PM »
That's probably good, because I'll be towing a 24 foot camper with this thing...and it's likely I'll tow in the mountains from time to time.  I ended up with these head gaskets: FEL-1020.  I don't think they'll help my compression ratio, will they?
« Last Edit: August 14, 2018, 04:22:12 PM by dmann »
« Reply #10 on: August 14, 2018, 04:40:29 PM »
Give us a yell before you drop anymore coin on parts.
The Comp Cams setup is extreme overkill.
The TFS heads look promising, but there is a huge rocker arm geometry problem.  You can't just slap these heads and rockers on and be good.   The rocker stand pads are raised by a net amount of about .250".  If you just bolt everything together, it won't be easy on the valve guides and seals.
dmann
« Reply #11 on: August 14, 2018, 04:55:48 PM »
Thanks Blykins - I'll get it mocked up and see what it looks like.  I'll take measurements and pictures.  Unfortunately for me I only have a lathe but not a mill :-( so if I need something milled I'll have to outsource it.  I really would like to get a mill at some point though.  It sounds like my cam won't be ready until next week.
« Reply #12 on: August 14, 2018, 05:06:03 PM »
The cam may take a bit.  Most suppliers are all out of FE cam cores right now.
FElony
« Reply #13 on: August 14, 2018, 06:19:28 PM »
He said it was a Lunati, and Ross said it was a good choice.
FElony
« Reply #14 on: August 14, 2018, 06:22:48 PM »
Or he can put a turbo on it and not worry about too-big ports on too-small engine.  >:(
