Author Topic: PCV Question  (Read 9890 times)
Pontiac787
PCV Question
« on: May 29, 2018, 10:31:24 AM »
Hi All,
I'm thinking of adding a PCV to a '63 427 with a 6V intake.  I did some searching around and found good info but none of the photos in the posts were working.  My current set up is one breather on the driver side valve cover and the vent on the rear of the intake that I assume the road tube would have attached to.
My questions are:
1) Should I install the PCV at the valve cover or the vent that stands up from the rear of the intake?
2) If I do vent from the valve cover do should I plug the vent on the rear of the intake?
3) I only have one vacuum port on the intake (at the rear).  It is currently connected to the power brake booster.  Can I tee this port and run both the PCV and brake booster from it?
Thank you!
gt350hr
Re: PCV Question
« Reply #1 on: May 29, 2018, 10:45:30 AM »
   The "typical" PCV screwed into the port at the back of the manifold and then ( via a rubber hose) went to the same location as the road draft tube using a plate with a hose nipple on it. There should be a "basket" under the plate that has mesh material in it as an oil separator.
Re: PCV Question
« Reply #2 on: May 29, 2018, 10:47:03 AM »
Here's a couple pretty clean options.
https://www.ebay.com/itm/FORD-FE-MANIFOLD-REAR-PCV-KIT-352-390-406-427-428/263636282154?hash=item3d61f26b2a:g:87AAAOSwcEtZkgdQ&vxp=mtr
https://www.ebay.com/itm/REAR-PCV-FE-FORD-352-390-406-427-428-INCLUDES-HARDWARE/142809994857?hash=item2140239669:g:nTwAAOSwcg9Zq--W&vxp=mtr
Last time I did one, I went to Napa and looked through the PCV boxes, found one that was threaded, drilled and tapped a manifold blankoff plate to match. Same idea as the top link, but less money and more of my time.
Pontiac787
Re: PCV Question
« Reply #3 on: May 29, 2018, 11:36:00 AM »
Thanks guys.  Can I share the manifold port with the brake booster or do I need a dedicated port?
Re: PCV Question
« Reply #4 on: May 29, 2018, 11:44:58 AM »
Mine.
Pontiac787
Re: PCV Question
« Reply #5 on: May 29, 2018, 03:30:40 PM »
I found this one as well https://www.ebay.com/itm/M1003-FORD-FE-Engines-Billet-Intake-Manifold-Breather-Plate-w-Grommet-6061-USA/122641888084?hash=item1c8e06b354.  This may be a little cheaper for me.
How particular do I have to be about the PCV valve itself?
Re: PCV Question
« Reply #6 on: May 29, 2018, 03:56:05 PM »
That one is just a lid, no pcv, no basket, etc.  You more than likely have the basket already under your existing breather.  I'd check and see if it's usable.
I used a cheapo pcv valve from summit.  I restrict mine a good bit anyhow.
Pontiac787
Re: PCV Question
« Reply #7 on: May 29, 2018, 08:33:24 PM »
Yes.  I have the basket and filter material in place.  Do you know a source where I could get some new filter material?  Or should I just degrease what I have?
Re: PCV Question
« Reply #8 on: May 29, 2018, 08:40:41 PM »
You can buy it, i forget where.... but I'd just soak yours in some carb cleaner and see what falls out of it :P
As expensive as all these parts are, I'd be playing the "gee what can I keep" game.
If it was a new high dollar build maybe I'd look at it differently.
Pontiac787
Re: PCV Question
« Reply #9 on: May 29, 2018, 08:59:31 PM »
That's what I was thinking.  The mesh is in fine shape, just a little gunked up.
TJ
Re: PCV Question
« Reply #10 on: May 30, 2018, 08:25:58 AM »
I fought with a PCV system for a while and finally got it to quit sucking oil mist by using an expensive Wagner adjustable valve.  Wish it would have occurred to me to just restrict the hose like Drew does.
Now I just run without a valve and don't miss it.  My four corner breathers seem to stay fairly dry.  Might clean them once a year.
I think it's just about as important to make sure the engine hits at least 180F on a regular basis to drive off moisture and other vapors.
Pontiac787
Re: PCV Question
« Reply #11 on: May 30, 2018, 08:54:50 AM »
Drew - how do you restrict the hose?  Just use a smaller diameter?
Re: PCV Question
« Reply #12 on: May 30, 2018, 09:03:11 AM »
Use a short piece of hard plastic or aluminum round stock. Drill say a .125 hole in the middle (experiment here) and stuff the piece up into the rubber hose.
Re: PCV Question
« Reply #13 on: May 30, 2018, 09:25:26 AM »
Smaller hoses fit within the larger hose.
1/4 inch fits perfectly within 3/8 for example....  With weak intake vac at idle, a pcv doesn't really work as designed, it kinda flops around when it should be sealed.  I just stuff things in the main hose until it works right..... kinda part of tuning.
I've heard some new cars don't even use a pcv, just a small restrictor.  No expert on it all tho, just guessing my way to glory.
Re: PCV Question
« Reply #14 on: May 30, 2018, 10:26:04 AM »
I have used a .060 restrictor in a few swoopy builds that did not want any oil mist underhood, but needed a breather.  Seemed to work pretty well.
