Author Topic: PCV Question  (Read 9900 times)
Re: PCV Question
« Reply #15 on: May 30, 2018, 10:29:19 AM »
I use a 3/16 brake line union fits in hose snug. Really like the BT one in the picture.
Pontiac787
Re: PCV Question
« Reply #16 on: May 30, 2018, 02:06:46 PM »
I'd be playing the "gee what can I keep" game.
I may just use a piece of 1/2" hose to connect a PCV to the nipple already on the manifold plate to start off with.  I'd like to buy the plate like you have but the guy hasn't gotten back to me if he would sell it separate from the basket.  He sells the baskets separate so why not?
Did you tap yours to a pipe thread?  I don't think I've ever tapped a something for pipe fitting.
Re: PCV Question
« Reply #17 on: May 30, 2018, 04:50:49 PM »
If it's thick enough, go for it.  Mine just uses a nipple to hose to pcv which is screwed into a 45 degree fitting and into the intake.
I think I either used this valve, or one that looked like it.
https://www.summitracing.com/parts/smp-v100/overview/
alf1960
Re: PCV Question
« Reply #18 on: June 02, 2018, 11:57:13 PM »
here is what is on my tripower from HP Trends. He sells these separately. http://hptrends.com/PCVFitting.htm
Pontiac787
Re: PCV Question
« Reply #19 on: June 04, 2018, 10:59:21 PM »
Thanks Alf. That is the setup I’m going to use if my prototype works ok.  Instead of the brass T I’m going to use an Earl’s 3/8 to 1/4” Y splitter.  Is there any type of restrictor in your setup?
alf1960
Re: PCV Question
« Reply #20 on: June 05, 2018, 05:55:14 AM »
I `m not sure about that sorry.
6667fan
  • Every Second Counts
Re: PCV Question
« Reply #21 on: June 06, 2018, 06:52:39 AM »
Is the valley tray installed? JB.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
