Author Topic: 62 Falcon, new engine, new attitude  (Read 39269 times)
62Falcon390
« on: May 26, 2018, 07:10:37 AM »
last year I cooked my engine so I pulled it out and took to my neighbours machine shop. The 352 checked good so got it bored to 390 bore and stuffed in 390 crank, rods and new pistons.. Got the engine balanced and blueprinted, my heads checked over (6 bent valves) put my solid cam back in. Picked it up last weekend, painted and assembled. and stuck it in the car.. Went for a few test drives so far and the efi is learning good after I had to reset everything being a totally different animal.. All I can say now is it is so fun to drive and pretty scarey compared to the last engine that was in (but it was a totally stock 1960 352 that I stuck on bigger heads and a solid cam not really meant for a 352 :)
62Falcon390
Re: 62 Falcon, new engine, new attitude
« Reply #1 on: May 26, 2018, 07:12:28 AM »
hood is on and front emblems
62Falcon390
« Reply #2 on: May 26, 2018, 02:56:18 PM »
last set of pictures
« Reply #3 on: May 26, 2018, 05:31:58 PM »
Looks really good!  Your induction system really stands out...
fastback 427
« Reply #4 on: May 26, 2018, 06:31:05 PM »
Very cool. Glad to see you  got it done.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
62Falcon390
« Reply #6 on: May 27, 2018, 09:44:20 AM »
No smoking! Sounds much better at idle also. I'll bet it's a night and day difference in how it runs! Better make sure you've got a real seat in it this time ;)
62Falcon390
« Reply #7 on: May 27, 2018, 09:50:34 AM »
it is unreal to drive this time around.. I have proper seats and 5 point harness if needed lol
« Reply #8 on: May 27, 2018, 02:04:25 PM »
Whats in it for a cam?
62Falcon390
« Reply #9 on: May 27, 2018, 02:10:55 PM »
comp cams custom solid grind
270/276 degrees @ 0.020"
240/246 degrees @ 0.050"
108 degree lobe separation angle
Gross lift .598"/.608" with 1.76 rockers
gdaddy01
« Reply #10 on: May 27, 2018, 05:48:10 PM »
why are you listed as a newbie ? I have been following your falcon build for years . just wondering
« Reply #11 on: May 27, 2018, 07:10:15 PM »
That is only based on post counts. Lots of guys that have been on the old forum for years, and some that have been on this one for quite a while but don't post a lot, are still "newbie"s. Obviously doesn't mean much as far as how long they've been around.
62Falcon390
« Reply #12 on: May 27, 2018, 07:17:45 PM »
I actually left this site for awhile.
gdaddy01
« Reply #13 on: May 27, 2018, 07:41:20 PM »
ooolllllll
cobracammer
« Reply #14 on: May 29, 2018, 11:09:59 AM »
Awesome.... Been watching this build for some time and was wondering where it went!  Looks great!
Jason
