Author Topic: Drilling a factory side Oiler for lifter/pushrod oiling  (Read 8322 times)
Ghoughton
« on: April 25, 2018, 06:07:03 AM »
Hey guys, I’m in search of someone capable of drilling a factory sideoiler block for lifter oiling
In the Grand Rapids  Michigan area. I want to run a T@D setup on my next build.
Any help is greatly appreciated. Thanks!
Ghoughton
Re: Drilling a factory side Oiler for lifter/pushrod oiling
« Reply #2 on: April 25, 2018, 06:58:17 AM »
Thanks, Barry is in Detroit which is a good couple hrs from me. And I’m not sure if he
Actually drills blocks. I know he can be tough to get a hold of, so I posted here. Ray Paquet
gave me a name a few years ago but I’ve forgotten who it was and where. Thus the fishing
expedition...
« Reply #3 on: April 25, 2018, 12:02:46 PM »
The Roush operation in Livonia Michigan has a boring mill that should be capable of doing that for you. They have an extensive establishment there and many phone numbers, but (734) 779-7006 should get you started.
 I'm actually a great fan of Barry's operation, but doing the proper job of such a task takes a  GREAT BIG machine. Roush's is of such a size you have to climb up on it to be able to  reach the working area.
« Last Edit: April 25, 2018, 04:07:54 PM by cammerfe »
« Reply #4 on: April 25, 2018, 12:22:39 PM »
Maybe between the two forums you could find a good swap for a hydro block.
CaptCobrajet
« Reply #5 on: April 25, 2018, 04:03:37 PM »
I drill them regularly, but probably 10 hrs from you.   Not many people do it, or know exactly how to attack it.  Ray may have mentioned Dave Wood in Holt Mi.  I'm sure Dave can do it if you can get him.
Blair Patrick
FB
« Reply #6 on: April 25, 2018, 05:27:25 PM »
drilling? drilling what? forgive me but i put T&D's on my engine and oil up the P-rods and i didn't drill anything. i blocked the passage going to the deck, but that's it.
the sideoiler is already a hydraulic block i would think no drilling is necessary....No? Blair?
thanks
« Last Edit: April 25, 2018, 05:31:03 PM by FB »
Fred
« Reply #7 on: April 25, 2018, 05:32:51 PM »
The OP has a solid lifter block....not drilled for lifter oiling.
FB
« Reply #8 on: April 25, 2018, 05:38:56 PM »
i guess i was just believing what i read, (sideoiler) i'll remember next time to not second guess myself....... ;D
Fred
Ghoughton
« Reply #9 on: April 25, 2018, 06:33:38 PM »
Thanks for all the reply’s fellas. And thanks for the name Blair. I’ll see if I can get a hold of Dave.
Also, this is indeed a solid lifter sideoiler. I have three of them. 1-C5 and two C7’s.
All solid lifter. Only the C8’s were drilled for hydraulic.
« Reply #10 on: April 25, 2018, 06:39:56 PM »
I also have a c5 solid side oiled. Although it's in several different pieces...  >:(
Ghoughton
« Reply #11 on: April 25, 2018, 06:45:48 PM »
Time to fire up the welder
andyf
« Reply #12 on: April 26, 2018, 12:46:06 PM »
Can you reverse oil with the T&D setup? We used a solid sideoiler for the 700 hp Car Craft engine and reverse oiled the lifters down the pushrods. That engine used the new Comp rocker arms. The rocker arms needed to be drilled and then we used T&D adjusters. It was easier to drill 16 rocker arms than to find someone who could drill the block........
Ghoughton
« Reply #13 on: April 26, 2018, 06:32:27 PM »
Thanks for the thought, but you can’t reverse oil with the race t@d set up. It uses a sub plate that attaches with the head bolts and covers up the original oil supply. Also the rockers shafts are in small pairs as opposed to one long hollow shaft. So the only way to oil the rockers is up through the pushrods
