Author Topic: Fuel Pump Ecentric  (Read 4193 times)
Faron
Fuel Pump Ecentric
« on: April 23, 2018, 08:41:56 AM »
Planning on adding a Mech Fuel pump to my car , I jave a few Ecentrics , how can I tell if is for an FE ( havent had a Mech Pump on the car since the early 80"s ) LOL
shady
Re: Fuel Pump Ecentric
« Reply #1 on: April 23, 2018, 08:53:47 AM »
IT IS 2.75 IN DIAMETER & 13/16" TALL. THE DOWEL HOLE IS ELONGATED. Sorry for shouting.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
BigBlueIron
« Reply #2 on: April 23, 2018, 10:39:39 AM »
Use a one piece and verify the dowel is long enough and of course a heavy washer that covers part of the dowel. Same as a 385 series if you need to buy a new one.
I have yet to see a two piece correctly fit an aftermarket timing set. What happens is it wedges the outer shell not allowing it to rotate then the inner doesn't sit flat for the bolt which then distorts, usually breaking which reduces clamp load. I have taken apart several like this but cam bolt was still tight surprisingly.
Faron
« Reply #3 on: April 23, 2018, 10:43:57 AM »
thanks guys !! :)
« Reply #4 on: April 23, 2018, 10:45:35 AM »
I run only electrics, I would be an electric pump and filter on it personally.
Faron
« Reply #5 on: April 23, 2018, 02:30:27 PM »
I have that as well , but its noisey , I plan to cruise on the mechanical pump and flip a switch and add the elec when needed
« Reply #6 on: April 23, 2018, 02:38:46 PM »
I use a Carter P4600HP it's quiet and feeds my 447ci engine sufficiently.
