Author Topic: Ultrasonic thickness gauge help  (Read 3824 times)
Machspeed
« on: April 19, 2018, 10:08:05 PM »
Has anyone here modified the flat tip of a transducer probe so it will have a radius? Pictures? I ordered a cheap unit on eBay that has a flat tip so it doesn't work for cylinder walls which is my primary reason for buying it. I read somewhere about someone doing this but I can't find it now. I checked the unit with gauge blocks and it seems to be pretty accurate and I don't want to mess it up. The tip is stainless steel with a plastic core and a divider for the two sides. The wires are not removable so I cannot machine it in a lathe. I'm thinking about putting it in the mill or just using a grinding wheel to hand work a radius on the tip.
Re: Ultrasonic thickness gauge help
« Reply #1 on: April 19, 2018, 10:30:41 PM »
I'd say many of us has made that modification.  I recomend using a fine hand file, take your time and creep up on it. It dosen't take much. There should be a few post here about it and picts as well .
« Reply #2 on: April 20, 2018, 12:33:31 AM »
Here's a link to a discussion last fall about it. A sanding block does well. I'll see if I can get my pictures on the post working again.
http://fepower.net/simplemachinesforum/index.php?topic=5449.msg58346#msg58346
« Last Edit: April 20, 2018, 01:23:37 AM by thatdarncat »
66FAIRLANE
  • Andy
« Reply #3 on: April 20, 2018, 03:26:37 AM »
I laid wet & dry in the bore and rubbed the probe on that. I bought the same one as in Kevins link.
Machspeed
« Reply #4 on: April 20, 2018, 05:47:44 AM »
Thank you for the replies. The link shows exactly what I needed.
