Author Topic: Part I.D.  (Read 9691 times)
Royce
Part I.D.
« on: February 20, 2018, 11:27:24 AM »
I think I know what this is but I thought I would ask the experts.. Us Y block/MEL guys sometimes have incomplete knowledge of modern engines.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Part I.D.
« Reply #1 on: February 20, 2018, 12:07:10 PM »
An oil filter mount as you know. But it appears to allow an oil cooler hookup. Maybe marine or heavy truck?  :-\
Royce
Re: Part I.D.
« Reply #2 on: February 20, 2018, 12:19:23 PM »
I was hoping for Super Cobrajet part but I am thinking truck too.
1992 BMW V-12 5.0
Re: Part I.D.
« Reply #3 on: February 20, 2018, 12:22:13 PM »
Hah! Super Cobra Jet!
But.....the later GT-40, FE equipped distance racers did of course use engine oil coolers. I don't know if they used the two taps on a similar filter mount to route the oil to a cooler. Anybody know?
Re: Part I.D.
« Reply #4 on: February 20, 2018, 01:48:26 PM »
LMAO modern engines!  Not sure what you got there, Royce, I've never seen one like that...
Re: Part I.D.
« Reply #5 on: February 20, 2018, 01:57:01 PM »
If it's what it looks like, it is a dual port adapter for the 427. Worth some money...
scott foxwell
Re: Part I.D.
« Reply #6 on: February 20, 2018, 02:28:58 PM »
One channel has to be "out" and the other "in" for that to work with a cooler. That's the "in" passage to the block, from the filter. Just looks to be two sources for oil pressure senders unless that top horizontal passage isn't drilled all the way through.
Re: Part I.D.
« Reply #7 on: February 20, 2018, 02:54:29 PM »
Scott is right, not intended for a cooler. Prolly has something like a C3AE-6884-A number?
Royce
Re: Part I.D.
« Reply #8 on: February 20, 2018, 03:09:56 PM »
You nailed the part number.
Both passages intersect the filter outlet passage.
1992 BMW V-12 5.0
GJCAT427
Re: Part I.D.
« Reply #9 on: February 20, 2018, 04:29:58 PM »
Yep the 427 dual port adapter. I got 2 of them setting in the garage waiting to go on my 427s. Always looking for another.
ntheogen
Re: Part I.D.
« Reply #10 on: February 21, 2018, 04:42:53 AM »
Those are hard to come by and fetch a few pennies. I have one someone made, the only way to tell is by the incorrect part number.
babybolt
Re: Part I.D.
« Reply #11 on: February 21, 2018, 08:04:17 AM »
64 64 Galaxie 427, two ports for two oil pressure sensors, stock idiot light and gauge.  Hard to find.
Royce
Re: Part I.D.
« Reply #12 on: February 21, 2018, 09:04:13 AM »
hmmm even better than an SCJ part..!!!  Without arousing the ire of the site owner for doing commerce on this section of the forum anybody want to give a ballpark on value?
1992 BMW V-12 5.0
Re: Part I.D.
« Reply #13 on: February 21, 2018, 09:19:45 AM »
Last couple I saw on eBay went for $250-350.
gt350hr
Re: Part I.D.
« Reply #14 on: February 21, 2018, 12:34:14 PM »
   +1  427 only.  There is another odd one that was made for the  Cammer .  The front port is angled and it has an XE number instead.
