Author Topic: my 67 gta fairlane  (Read 9204 times)
fastback 427
my 67 gta fairlane
« on: September 03, 2017, 05:30:17 PM »
Finally got my fairlane to the track this summer. This a driver that sees about a thousand miles a year.
Engine is a .60 over 390 cross bolted. Old trw 12 to one pistons. Truck rods, arp bolts. Heads are aluminum  dove f5, hand ported by me. They flow 290 at .600 lift. Dove rockers, Dove spider itake, 950 biggs carb. Cam is .569 intake .580 exhaust, 108 lobe. Trans is c6 with 3600 converter, 3.89 gears, full spool.
Performance was 1/8 mile, 7.76 at 88.6 mph, 1.71 60ft.
Had some tuning issues and broke a rocker adjuster on the last pass, but i think there is a couple tenths left with some proper tuning.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
57 lima bean
Re: my 67 gta fairlane
« Reply #1 on: October 30, 2019, 02:09:52 PM »
Can you give some info on the carb. from Bigg's?How streetable is it?
fastback 427
« Reply #2 on: October 31, 2019, 10:35:03 PM »
Sure can, what info do you need? It is pretty streetable, tuning is a little over my head with the air bleeds. They did a 1050 dominator for me years ago and it made a world of difference in power and throttle response.
Jaime
top end toploader
57 lima bean
« Reply #3 on: November 01, 2019, 12:44:07 PM »
Pondering a 1000 cfm 4150 or bringing my shelved Dominator back into play.I'll give Bigg's a call and see what they have to say..........Thanks
57 lima bean
« Reply #4 on: December 03, 2019, 02:49:36 PM »
               I've learned that purchasing a Bigs carburetor is like inviting Red Sovine to St Jude.
fastback 427
« Reply #5 on: December 03, 2019, 07:45:11 PM »
How so?
Jaime
top end toploader
JERICOGTX
« Reply #6 on: December 08, 2019, 09:47:17 PM »
That Bigs carburetor works better as a door stop, than a controlled fuel drip.
57 lima bean
« Reply #7 on: December 17, 2019, 01:28:45 PM »
How so?
                 No secondary fuel flow after it was said to flow "Mint" as tested.
                    Edit.....After having it fail on the dyno,disassembly and air check circuits
                              saw nothing wrong.Installed it on my engine with secondary operation
                              only.It flows mint!...Zed and Red are dead.
« Last Edit: April 26, 2020, 03:26:54 PM by 57 lima bean »
