Author Topic: m.p.g.?  (Read 14839 times)
unclewill
m.p.g.?
« on: August 10, 2017, 06:39:51 PM »
Just made a "scientific" run to the Paradox Valley and back - exactly 13 miles per gallon over 110 miles of mixed back road driving with *several* third and fourth gear pulls.  Pretty good?  How does your FE compare?
Autoholic
Re: m.p.g.?
« Reply #1 on: August 10, 2017, 07:17:47 PM »
exactly 13 smiles per mile
Fixed that for you.  :)
~Joe
stroked67
Re: m.p.g.?
« Reply #2 on: August 10, 2017, 07:53:00 PM »
Shoot that's pretty good man! I'm getting about 9mpg in my 463 powered 67 galaxie, and about 3mpg when I "drive" it.  ;D
unclewill
Re: m.p.g.?
« Reply #3 on: August 10, 2017, 07:55:27 PM »
I took the camera but didn't film for even a second...this drive was pure self indulgence.  The sound of the side dump 3" exhaust is intoxicating, traffic was light, cool temps, great scenery.  Smiles indeed.
Re: m.p.g.?
« Reply #4 on: August 11, 2017, 03:52:20 AM »
pretty unscietific  but fresh engine just broke in the cam 390+060
streetmaster intake comp  282 s holley streetavenger 870 cruise o matic
in 64 Galaxie 16 mpg highway cruising 60-65
did some fine tuning since that
Re: m.p.g.?
« Reply #5 on: August 11, 2017, 07:52:43 AM »
MPG?   Don't really know as my '69 F100 is missing the speedo cable.  I smile when I drive it, just kinda cringe when I have to pull in and fill it up.....again.  428CJ, 2x4, 4spd, 4.546 gears.  Not a good "mileage" combination.
Now the blower car, when I ran 600's on it, would get pretty decent mileage.  I drove it 160 miles round trip to Thompson Raceway a few years back.  I was pleasantly surprised when it made the trip without filling up(4 spd/3.89 gears).  Since I put the 660's on it, well, it's not so good anymore.  On well.
shady
Re: m.p.g.?
« Reply #6 on: August 11, 2017, 08:26:10 AM »
stone stock 63 gal 390 4 sp. with 350s, 12mpg no matter how I drive it.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
unclewill
Re: m.p.g.?
« Reply #7 on: August 11, 2017, 09:20:34 AM »
13 mpg x 20 gallons gives me 260 miles of theoretical range.  Not a Prius, but not bad for an 8.0L engine with no overdrive.
Re: m.p.g.?
« Reply #8 on: August 11, 2017, 09:21:38 AM »
Best I ever got was 16 out of my '68 F250 Highboy, but that was fresh out of a rebuild with pretty ideal driving conditions (flat highway miles). It had a solid lifter 390, mild build with a 750 Holley and stock S intake. That was with a verified speedometer accuracy. My Galaxie gets about 13-14 in the same conditions, automatic with stock original untouched 390 with dual exhaust being the only upgrade. My Mustang? I don't check it. Don't care either ;D
Driving style has a LOT to do with the results you get. I have friends who could cut that mileage in half, driving the same car on the same stretch of road.
mike7570
Re: m.p.g.?
« Reply #9 on: August 11, 2017, 09:31:40 AM »
If you think your FE powered car doesn't get good gas mileage just buy a motorhome and drive it a little. My V10 gas motorhome got 8 mpg once downwind and I thought that was good!
It can suck a 75 gallon tank dry in 375 miles when towing.
KMcCullah
Re: m.p.g.?
« Reply #10 on: August 11, 2017, 09:49:24 AM »
That's pretty good for a lot of cubes. This is with the FiTech? Paradox Valley in southwestern CO?
The 416 in my Highboy has been averaging 9mpg with a 750 vac secondary carb.  That's with a 2500 foot elevation change to and from work.
Kevin McCullah
Re: m.p.g.?
« Reply #11 on: August 11, 2017, 10:22:15 AM »
LOL. make you not worry about it - F350 7.5L gas + 34' trailer = 6.8 MPG.  Dual 18 gallon tanks, switch tanks at 90 miles.   8)
Re: m.p.g.?
« Reply #12 on: August 11, 2017, 10:55:32 AM »
Ya, my '96 F350/460/auto/4.10 got 7 mpg pulling my 14K trailer.  My V10 got 9 mpg, the PSD got 12 mpg.  My Mack is around 8 mpg.
Re: m.p.g.?
« Reply #13 on: August 11, 2017, 11:42:58 AM »
i drove my 66 comet 390 4 speed,3.25 gear to the beach years ago and my friend followed me in his 350 chevyII and he used 5 dollars more gas than i did getting there.back then gas was less than 1 dollar a gallon so he used quiet a bit more than i did,and i was breaking in a new 390 so i ran it at different speeds and kicked the 4 barrel in several times too
« Last Edit: August 11, 2017, 11:48:15 AM by fryedaddy »
Re: m.p.g.?
« Reply #14 on: August 11, 2017, 12:10:13 PM »
I want to make a tank to put in the back of my '70 F350 that I pull my 28' trailer with. Something that I can tie into the main cab tank with a short line and valve and refill it as I'm going down the road. It'd actually save me money as well, because gas is always quite a bit cheaper near me than anywhere on the road.
