Author Topic: Center an original cast bellhousing?  (Read 4296 times)
ewo357
« on: July 24, 2017, 09:03:27 PM »
Do I need to check the centering of an original cast bellhousing that is on an original cast engine block? Early 70s 390 block, C5AA-6394-A bell, TKO trans
I'm not worried about buying the tools needed but I am worried about doing it wrong or second guessing a reading and screwing something up.
Thanks in advance
preaction
Re: Center an original cast bellhousing?
« Reply #1 on: July 24, 2017, 09:27:27 PM »
Shop manual tells you how to do it.
ewo357
« Reply #2 on: July 24, 2017, 09:55:45 PM »
I'm not asking how to do it. I'm asking if it should be done when NOT using an aftermarket bell?
« Reply #3 on: July 24, 2017, 10:00:51 PM »
most likely not ...but you never know . Have the block and bell
worked together before? If so will probably work now
ewo357
« Reply #4 on: August 04, 2017, 08:24:30 PM »
They were not from the same car.
