Author Topic: Marine 427  (Read 3686 times)
tomsfe64
Marine 427
« on: April 30, 2017, 12:36:34 PM »
This is the only photo of 2 marine engines available for sale. Is this a 427 fe? If so is this a desirable block?
Re: Marine 427
« Reply #1 on: April 30, 2017, 02:06:29 PM »
It sure looks to be as you compare these photos:
https://www.google.com/search?q=chris+craft+427+ford&rlz=1C1SAVS_enUS541US568&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjpveHO78zTAhWI7CYKHSD-DygQ_AUICygC&biw=1024&bih=490
It's possible at some time that a 390 short block was swapped in. Best bet? Yank intake and one head. Measure one to bore.
A stock bore 427 has a bore size of 4.23".
A 390 has a 4.05" bore.
« Last Edit: April 30, 2017, 03:54:51 PM by machoneman »
tomsfe64
Re: Marine 427
« Reply #2 on: April 30, 2017, 05:51:47 PM »
Are these marine 427 blocks sideoilers? If in good shape what might one of these engines be worth running?
Re: Marine 427
« Reply #3 on: April 30, 2017, 06:34:16 PM »
Here. Carefully read this older post and all your questions, save the value, will be answered.
https://www.ford-trucks.com/forums/64722-marine-427-the-good-and-the-bad.html
