Author Topic: Power steering pump question  (Read 5978 times)
427Fastback
« on: February 01, 2017, 10:54:11 PM »
I have a P/S rack in the 66 428 car.Will the stock 68-70 p/s pump work on the rack or do I need a different pump....Not worried about hoses,i can make those...Thanks
« Last Edit: February 02, 2017, 12:45:48 AM by 427Fastback »
1936 Diamond T 212BD
1990 Grizzly pick-up
bn69stang
Re: Power steering pump question
« Reply #1 on: February 05, 2017, 03:25:41 PM »
I believe you need the later model pump , i did a unisteer power rack conversion on my 69 , if i remember there are different pressure s involved .. Bud
427Fastback
« Reply #2 on: February 05, 2017, 09:38:11 PM »
Thanks....I will have to do more research as I have had both answers now..I was under the impression that there was different pressures involved as you said....
« Reply #3 on: February 05, 2017, 11:06:49 PM »
If you look in the right place (Speedway hot-rod catalog perhaps) there are valves that can be used to cut down on over-pressure to make power steering work better.
427Fastback
« Reply #4 on: February 06, 2017, 06:06:24 PM »
So...the early pumps make too much pressure for the rack ???
« Reply #5 on: February 06, 2017, 10:59:16 PM »
IF your pump (how should I know?---I don't know how much your rack uses) makes more pressure than you need, the above method is an alternative to changing the pump. Glad I could be of help!
« Reply #6 on: February 06, 2017, 11:41:31 PM »
I'm getting close to being in this area also. I haven't done to much research yet but I do know that Flaming River specifies low pressure pumps for their power racks. Sorry I don't have more.
427Fastback
« Reply #7 on: February 07, 2017, 12:27:13 AM »
Thanks..all info is good.I would really like to keep the stock pump look...I have generally stayed far away from early Mustang power steering stuff..
I have a power rack in the 68 but I bought all the stuff (pump included) from AGR Steering.I made my own mounting brackets and remote reservoir tank..
If the stock pump is to high a pressure as CammerFE says I can cut the pressure down...
More research..
Thanks
fe-starliner
« Reply #8 on: February 07, 2017, 12:00:59 PM »
I bought a power steering kit from the defunct "Wurth-it Designs" and it uses a GM rack from a Chevy Citation.  No pump included with the kit.  I also wanted to keep the original look for my '60 Starliner so I used a '60 power steering pump and had lines made.  My Starliner originally wasn't built with power steering.  It works with no problem, except at full lock it squeals.  Maybe that's because of the pressure being too high?
1960 Starliner, 406-6V, TKO-600, 4.11 9"
1961 Starliner, 427 4V, SS700 5 speed, 4.56 9"
1968 F-100 SWB, 352 4V, C6, 3.25 9"
2012 Mustang, 226" V6, 6 speed auto, 3.31 8.8"
bn69stang
« Reply #9 on: February 07, 2017, 06:26:04 PM »
Im not really sure what the difference would be , i just used the pump they sent with the rack , there instructions said not to use a factory pump . I actually like the look of the later model pump , But i do know that the way the car steers and drives is night and day difference .. you will like the rack .. Bud
