Author Topic: Lykins Motorsports 427MR, 526 hp  (Read 12619 times)
« on: January 25, 2017, 03:39:48 PM »
Performance Summary:
      Cubic Inches:    433     Dyno brand:  Stuska
      Power Adder:               Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:   526 @ 6000
      Peak Torque:   511 @ 4750
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 S/O service block, 4.270" bore
   Crankshaft brand, cast or forged, stroke, journal size:  Fomoco C5AE-D
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged flat top, 10.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  FM 125M20, FM 8-7170CH20, Durabond cam bearings
   Piston rings brand, size, other notes:  Total Seal 1/16, 1/16, 3/16, 4.270", standard tension
   Oil Pump, pickup, and drive:  Melling HV, Canton pickup, Melling pump drive
   Oil pan, windage tray, oil filter adapter:  Canton T-sump, no windage tray, factory Ford oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Comp Cams hydraulic    roller, 235/241 @ .050", 110 LSA, 103 ICL, .600/.600
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory Ford cover
   Cylinder heads brand, material, port and chamber information:  Fomoco C5 MR heads, 73cc chamber
      Intake               Exhaust
      .100     75            .100   47
      .200     149          .200   88
      .300     223          .300   121
      .400     273          .400   154
      .500     308          .500   178
      .600     314          .600   199
      .700               .700
      .800               .800
   Flow bench used, location:  SF600, Lawes Mayfield Motorsports
   Intake valve brand, head size, stem size:   SI stainless, 2.250", 11/32"
   Exhaust valve brand, head size, stem size:  SI stainless, 1.750", 11/32"
   Valve springs brand, part number, specs:   Comp Cams 930, 150/350
   Retainers and locks brand, part number, specs:  Comp Cams 741
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory non-adjustable  (all new)
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend custom
   Valve covers, brand, type:  Tony Branda chrome pentroof
   Distributor brand, advance curve information:  Fomoco C5 dual point, Pertronix , 40° total, by 2800
   Harmonic balancer brand:  Powerbond PB1111ST
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Ported, factory Sidewinder
   Carburetor(s) brand, type:  Custom Quick Fuel HR-780, zinc finish
   Exhaust manifolds or headers brand, type:
« Last Edit: August 16, 2020, 05:51:10 PM by blykins »
Re: 427MR, 526 hp
« Reply #1 on: January 25, 2017, 03:42:12 PM »
Re: 427MR, 526 hp
« Reply #2 on: January 25, 2017, 09:00:38 PM »
Awesome Brent! It's great to see what the old parts will do. That's very respectable.
chris401
Re: 427MR, 526 hp
« Reply #3 on: February 04, 2017, 12:27:30 AM »
That is a clean piece of iron. No magic vat can replace hours of blasring and scrubbing. What exhaust did you use?
Re: 427MR, 526 hp
« Reply #4 on: February 04, 2017, 07:10:48 AM »
Actually, the block and heads got baked and steel abrated.   No scrubbing required.  :)
I used our normal FE dyno headers.
chris401
Re: 427MR, 526 hp
« Reply #5 on: February 04, 2017, 10:16:01 AM »
My employers were too cheap or short sighted. Our dip was not heated or aggitated and for the most part we cleanded the split aluminum cases by hand. When I worked in automotive I didn't get back any engines from the machine shop accounts that clean either. It would take me another couple of hours to get it like I wanted. Good work.
« Last Edit: February 04, 2017, 10:18:16 AM by chris401 »
WerbyFord
Re: 427MR, 526 hp Big-F or Little-f ?
« Reply #6 on: May 04, 2019, 02:42:49 PM »
Brent,
It's been a while but do U recall if these medium riser heads were Big-F or Little-f ?
c-reed
Re: 427MR, 526 hp
« Reply #7 on: June 17, 2019, 07:40:31 PM »
Hey Werby, I was hoping Brent would respond as I wanted to know as well. But, after looking closely at the casting # and date code placement in the last picture I believe these are the small f heads. From what little I understand the big F head had a different layout of the casting # and date code as per the other forum. Here's a pic and the link to the thread.
https://www.fordfe.com/super-stock-drag-illustrated-tasca-68-1-2-cj-test-t101217-s40.html
