Author Topic: Real cool piece  (Read 7607 times)
428kidd
Real cool piece
« on: January 06, 2017, 10:35:17 PM »
on ebay, not mine nor do I know the guy selling it. Wasn't really posting it for the ad more for the info behind it. If its in the wrong spot fell free to move it Jay.
http://www.ebay.com/itm/Ford-SOHC-427-Belt-Cam-Drive-/122301282537?hash=item1c79b978e9:g:dMAAAOSwZQRYb-Qv&vxp=mtr
« Last Edit: January 06, 2017, 10:56:48 PM by 428kidd »
KMcCullah
Re: Real cool piece
« Reply #1 on: January 07, 2017, 10:26:04 AM »
Pretty simple looking when compared to the chain drive. I'm not a degreed mechanical engineer but I have converted a few V-belt drives and chain drives to Gates Poly Chain. I'm saying the amount of wrap on the crank pulley is not enough to prevent the belt from skipping. I'm betting we would be surprised at the pulling force required to zing everything on both heads to 9800 RPM. Maybe Jay can expand on this? I'm really skeptical of the claim "tested to 9800 RPM".
Kevin McCullah
Re: Real cool piece
« Reply #2 on: January 07, 2017, 10:34:49 AM »
I just posted similar on the old forum, a second idler would sure help wrap that lower gear better.  One backfire it looks like it would strip the belt
« Last Edit: January 07, 2017, 11:01:56 AM by machoneman »
Re: Real cool piece
« Reply #4 on: January 07, 2017, 11:19:17 AM »
My guess is that it works fine, although more wrap on the lower pulley would certainly be better.  My objection to the setup is price (3.5X more expensive than a top of the line chain drive) and appearance.  Aesthetically, I think it looks ugly compared to the stock SOHC setup; no stock front cover, hacked off valve covers, etc.  The good chain drives available now using the 0.250 pin roller chain are trouble free.  Why would anyone cut up the front of their engine to use one of these?
Re: Real cool piece
« Reply #5 on: January 07, 2017, 01:43:42 PM »
I concur as to the need for more pulley wrap - just looks shaky - even if it does work.
I don't mind the cosmetics - I can make it pretty if desired.
I do think chains are perfectly fine, and there is a lot of durability to be gained by working on the chain sprocket alignment - we find significant front to back issues on the current setups.
Re: Real cool piece
« Reply #6 on: January 07, 2017, 02:05:42 PM »
Question for you guys who have built them
If you were starting from scratch, no cammer parts on the bench, would it allow a standard FE front cover, reduce concerns of back plate leakage etc?
What's the cost of the cammer back plate, cover, and chain assembly?
I could see it adding it's own set of accessory drive challenges because of the real estate it takes up front, but I wonder if it has some other benefit to a guy starting a fresh build?
Re: Real cool piece
« Reply #7 on: January 07, 2017, 02:25:08 PM »
if it was a class where the engine has to have the heads pulled after a few passes it's the only logical solution ..... like possibly a drag week situation , lol , agree on the wrap , they could add 4 teeth of bite with more rap easy
Re: Real cool piece
« Reply #8 on: January 07, 2017, 03:00:13 PM »
I gazed at one of those Jim Greene setups in Ron Miller's Ford Power Parts shop a long time ago.  The belt is most certainly up to the task of powering those cams, x10 at least!  It's a beast, though I agree a better wrap at the crank would be a good thing.
I'm not a big fan of the aesthetics either, but it obviously served a useful purpose for timing stability/ damping and removing the heads on the race engine.
Now how about a Danny Bee - style Kevlar timing belt under the existing timing cover  ;) ;)
Re: Real cool piece
« Reply #9 on: January 07, 2017, 03:41:53 PM »
"Now how about a Danny Bee - style Kevlar timing belt under the existing timing cover."
Now that is a much better idea. Gilmer pulleys and a Kevlar belt....cool!
Re: Real cool piece
« Reply #10 on: January 07, 2017, 04:40:43 PM »
Good point about leakage from the back plate, those things are indeed tough to get sealed up.
Robert Pond sells the front cover for $850 and the backing plate for $250 if I recall correctly.  His chain drive with chain and gears is about $1000.
Re: Real cool piece
« Reply #11 on: January 07, 2017, 06:03:13 PM »
Agree there.  Front dress on these is either leaking - or about to start leaking.
I do not really like the whole deal of mounting the idler and tensioner to a plate mounted through a gasket.  Not real fond of trying to locate stub thrust with a snap ring through the front cover either.  Lots of parts to tolerance stack and no real way to check what you've done to the for & aft alignment.  I have one on the stand where we tweaked it to use a normal FE thrust plate and just let it float in the nose bearing in the cover.
A cogged belt would eliminate the alignment issues - they kinda fix themselves.
wsu0702
Re: Real cool piece
« Reply #12 on: January 10, 2017, 04:23:09 AM »
The lack of belt wrap looks worse in the main Ebay image because they did not install the lower right backside idler for some reason and the belt is very slack. I hear what you are saying though it looks like there is hardly any belt wrap on the crank pulley. For these Gates style timing belts you only need 6-7 teeth of full engagement contact to achieve 100% load rating and design life. Below is a pic of a properly installed Jim Green belt drive set-up. Does it have at least 6-7 full tooth engagement on the crank pulley?  Hard to say just by looking at the pic.
« Last Edit: January 10, 2017, 03:30:52 PM by wsu0702 »
