Author Topic: New Trick Flow FE cylinder heads & Intake  (Read 190459 times)
chilly460
Re: New Trick Flow FE cylinder heads & Intake
« Reply #300 on: July 29, 2018, 07:22:37 AM »
Nice little combo, Brent.  Quick swag there would be 525hp, 500lbft with peaks around 6300/4800 respectively.  I like all these ~390 builds to compare to the 383 Chevy guys
CaptCobrajet
« Reply #301 on: July 29, 2018, 08:12:45 PM »
Hey Brent, I just milled .250 off the stands on a T&D single shaft set-up, and it came out right-on.  Sounds like an RPM intake is a better fit for that combo.  I think I like the TFS intake so far......will dyno one on a 428 in a few weeks.  It seems to need less work than a Victor to get to a similar place........if a single plane is the right avenue.
Blair Patrick
« Reply #302 on: July 29, 2018, 09:00:00 PM »
Wow a quarter inch off the stands to get ‘em right?
CaptCobrajet
« Reply #303 on: July 29, 2018, 09:59:09 PM »
Yessir.  The pedestals on the TFS head are .300 taller, and the valves are longer.  Milling .250 off the rocker stands made it have really nice geometry.
Blair Patrick
« Reply #304 on: July 30, 2018, 07:37:52 AM »
Since the valves are longer, it sounds like the whole internal architecture is raised. Is that right? What's the purpose of that, to raise the port roof? I assume the valve seats are raised also? I don't get why TFS changed all this stuff, unless it was all for raising the roof of the port. Longer valves seem like somewhat of a drawback since there's added weight to the valvetrain.
« Reply #305 on: July 30, 2018, 11:32:33 AM »
BP, have you ever cut down a set of factory stands that much?  Or do you think it'd be easier to start with HR stands and shim up?
CaptCobrajet
« Reply #306 on: July 30, 2018, 10:32:57 PM »
I think I would just get good billet aluminum stands and machine them.  It would take a lot of shim under a High Riser stand, and they aren't cheap.  The "base" of the standard OE stand isn't thick enough to mill .250 and still retain a good platform.   We just put the shaft through the billet stands, and turn them upside down in the Kurt vise, and mill them all exactly the same.
Blair Patrick
« Reply #307 on: July 31, 2018, 04:49:06 AM »
Yeah, I went ahead and got a set of stands ordered yesterday.
« Reply #308 on: August 03, 2018, 05:46:40 AM »
Sneaking up on it.
I'm at .175".  Pattern is getting much better, but still some left in it.
preaction
« Reply #309 on: August 03, 2018, 11:08:10 AM »
This months Hemmings muscle machines has a Trick Flo ad that says with its Power port 175 heads and a 482 CI FE Car Craft  made over 700hp its just inside the front cover.
Joey120373
« Reply #310 on: September 15, 2018, 11:45:58 AM »
Thought this was best posted on this thread.
I don't want to start a new argument about dyno results on this thread, rather my intended purpose is to further healthy conversation about the TF heads.
Now that Brent has built and tested a nice little 395 with these heads that seems punch well above its weight, I am that much more confident that had this 700 HP 482 been tested elsewhere it would have put up similarly impressive results.
While it's probably not really a good idea to compare a ~530HP 395 to a ~700HP 482, it does add a bit more data to judge the heads by.
thoughts?
