Author Topic: Fe main caps.  (Read 5942 times)
Fe main caps.
« on: October 17, 2016, 02:02:17 PM »
Anyone here had or seen a set of these in person ?
Wonder if any are around anywhere or still available?
Re: Fe main caps.
« Reply #1 on: October 17, 2016, 03:00:20 PM »
Found this:  Bessel Motorsports
http://www.strokerkits.com/product/ford-fe-crankshafts-connecting-rods-rotating-assemblies/
They don't list the caps anymore?
Katz427
Re: Fe main caps.
« Reply #2 on: October 17, 2016, 03:13:08 PM »
Bessel is still around but I do not believe they ever sold the main caps separate. Look under blocks then call because these are offered with a fully machined block caps installed. Blair Patrick had one in his shop and maybe he will relate his experience. It may be found on forum 54 site.
Re: Fe main caps.
« Reply #3 on: October 17, 2016, 03:15:35 PM »
Thanks guys, I was just checking that out in the block section.
Just was curious..
Re: Fe main caps.
« Reply #4 on: October 17, 2016, 03:35:24 PM »
I was looking at the caps and I would say it would take quite the machining to fit them and doubt that most shops would touch it anyway.
The Program caps are simple compared to these.
Re: Fe main caps.
« Reply #5 on: October 18, 2016, 08:41:01 PM »
I've talked to them. They are very close to St Louis, MO. The drawback, to my mind, is that they want you to send them your block to have the caps fitted. And they ARE quite proud of them.
Re: Fe main caps.
« Reply #6 on: October 19, 2016, 09:28:32 AM »
With the tapered sides they cut in the block I'm betting it isn't done an old Bridgeport!!  Thus the pricey cost.
I think it is way overkill for a stock block.  If you want to spend that kind of money you might as well go aftermarket block and get crossbolt caps.
« Last Edit: October 19, 2016, 09:35:29 AM by BattlestarGalactic »
Re: Fe main caps.
« Reply #7 on: October 19, 2016, 09:59:10 AM »
Yeah, for sure not something I'd pay for. If i found a old set of used caps I would for sure do it myself though.
Re: Fe main caps.
« Reply #8 on: October 19, 2016, 06:01:54 PM »
Just incase anyone is interested, I had contact with Ronnie Besselman and he said he sold the machine shop part of his business.  He said that the new owner has the program for the caps and can and does still make them. Said he will make the caps only or will do the caps and block.
His contact info is:
Jay at 636-262-3114
