Author Topic: Valve spring tool on car  (Read 6670 times)
63.5xl
« on: October 11, 2016, 10:40:02 PM »
Anyone know of a good tool to replace valve spring on car for our rocker shaft type heads. I tried a search here but came up with nothing. I have dual spring and was going to leave the inner one out to break in cam.
garyv
Re: Valve spring tool on car
« Reply #1 on: October 12, 2016, 05:53:58 AM »
I have one made by Tim Olereich that he used to sell on e-bay but I don't see it listed now.
His Email is: conceptdesigneng@aol.com, phone: 262-388-2509
This bolts to the head and works great.
I don't know if he still sells them or not but might be worthwhile to call or email him.
garyv
« Reply #2 on: October 12, 2016, 06:23:42 AM »
+2 on Tim's.  It works great. Give him a call.
Check out this link.
http://carsxyz.com/detail/Valve-Spring-Compressor-Ford-FE-390-427-428-Cobra_261927689615.html
Gregwill16
« Reply #3 on: October 12, 2016, 07:33:43 AM »
+3 for Tim's tool I just bought one off eBay about a month or so ago and it worked great. What I would've preferred though was to find a fitting to go in the spark plug hole to use compressed air instead of the supplied rope to hold up the valves.
« Reply #4 on: October 12, 2016, 07:37:37 AM »
+4
Yeah, the rope wouldn't fit in a small plug application, so get an air adapter as well.
Otherwise it's a great tool, worked on my beehives with a lil finesse.
« Reply #5 on: October 12, 2016, 08:29:45 AM »
Most of the time you don't even need air, a rope, etc.  Put the piston at TDC, the valve seal will hold the valve up, and use a pen magnet to hold the valve stem if necessary on reassembly.  This is how I do it on the dyno....
« Reply #6 on: October 12, 2016, 07:18:58 PM »
+5.  I use that one, too.  It works great.   I just got some smaller diameter rope for my Edelbrock heads to ensure that the valve can't fall into the cylinder.
paulie
fastback 427
« Reply #7 on: October 12, 2016, 08:28:44 PM »
I use the hose from my compression tester connected to my air hose to hold the valve up.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
63.5xl
« Reply #8 on: October 12, 2016, 08:40:12 PM »
garyv
Gave Tim a call and I got one coming, Thank you for the phone number Gary and thanks to everyone else for chipping in with your post
