FE Technical Forum
Motor mount insulators
Topic: Motor mount insulators (Read 6213 times)
Landlubberatsea
Jr. Member
Jan
October 11, 2016, 09:32:52 AM »
Hi, does anyone here know of any stiffer insulators for a 390 in a 68 Torino?
I have the anchor 2240-41 now but they seem to be a little soft. Saw that Crites sell some for 70 dollar/pair, is there anyone here with experience from those?
-68 Torino GT with a 390 that turned out to be a 360 but now is becoming a 445....
Re: Motor mount insulators
Reply #1 on:
October 11, 2016, 10:40:54 AM »
So you have fixed the brake issue now. And had a test drive?
I think you need a chain from the head to the chassie or
a bolt through the insulator. There is a tread here somewhere
how to do the bolt through
Landlubberatsea
Jr. Member
Jan
Reply #2 on:
October 11, 2016, 12:00:12 PM »
Hi Lars!
Brake issue better and a short test drive conducted
https://drive.google.com/file/d/0B-_5p5YOvsfMc0t5bmVzTDlCZWM/view?usp=drivesdk
Rain and poor weather have stopped me from longer drives though but hopefully it will improve to the weekend.
Will the bolt improve the stiffness or will it just prevent it from splitting?
Thought about a torque strap as well but thought I would check out if there was any polyurethane insulators or such out there first.
Reply #3 on:
October 11, 2016, 12:59:00 PM »
amdscooter
Sr. Member
Reply #4 on:
October 14, 2016, 12:40:41 PM »
I pinned my mounts some time back. thread here:
http://fepower.net/simplemachinesforum/index.php?topic=651.msg5032#msg5032
Worked like a charm, no need for a chain and it's not as harsh as solid motor mounts when ur not leaning on the throttle hard.
GL
-scoot
Reply #5 on:
October 14, 2016, 03:35:02 PM »
If you use chain and leave a little slack (but not too much) in it, you will have both safety and no extra vibration.
ericwevans
Full Member
Reply #6 on:
October 14, 2016, 03:44:31 PM »
That takes me back to my high school days. :-) Cheap solution, and it works!!!
Eric Evans
1965 F-100, 352 FE, Tremec 3550
1960 Falcon, 306 SBF
Landlubberatsea
Jr. Member
Jan
Reply #7 on:
October 16, 2016, 03:49:59 AM »
Many thanks to all for your input, much appreciated
/Jan
FE Technical Forum
