Author Topic: Cam thrust plate with new COMP CAM  (Read 3576 times)
mungus
« on: September 08, 2016, 06:56:44 AM »
Hi again,
Another dumb question I cant help but ask!
The OEM cam thrust plate set up seemed to have a slotted thrust washer between the front face of the cam and the factory thrust plate. (see image).
PN 6265.
But when I look at most modern day cam installs on the web etc, that little thrust washer seems to have been left out.
Is this correct? Do the aftermarket cams all have a thicker front face that eliminates the need for that?
So you only have the thrust plate against the rotating cam's front face? (with some lube in-between I guess!)
As an aside I see COMP CAMS sells a 4 hole mounted thrust plate kit, with various thicknesses of thrust washers.
Looks a big deal. But I doubt my 380 HP cruiser needs that. If the steel plate was good enough for a CJ428 then it'll do me...
Simple question, so apologies, but better to ask!
« Last Edit: September 08, 2016, 07:00:13 AM by mungus »
68' Mustang S code GT Fastback. Motor in progress...
Re: Cam thrust plate with new COMP CAM
« Reply #1 on: September 08, 2016, 07:10:25 AM »
All aftermarket timing sets have the washer built into them - just discard it - or keep it as a collectors item.
mungus
« Reply #2 on: September 08, 2016, 02:26:47 PM »
Ahhh OK, thanks Barry. That explains it well.
