Non-FE Discussion Forum
flushing rust out of a running cars engine
Topic: flushing rust out of a running cars engine (Read 4169 times)
August 26, 2016, 08:04:55 PM »
what is the proper way to flush rust out of your engine in a car without taking it apart,i have rust in a 428,new engine,water passages was not cleaned during rebuild,getting alot of rust specs in the rad
Last Edit: August 27, 2016, 09:50:36 AM by fryedaddy
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
Re: flushing rust out of a running car
Reply #1 on:
August 26, 2016, 11:16:42 PM »
http://www.jalopyjournal.com/forum/threads/best-way-to-de-rust-cooling-system.943881/
Reply #2 on:
August 27, 2016, 09:45:16 AM »
thanks,is guess i will head to town and see what i can find to clean it out.i took a piece of panty hose and put it on my top rad hose and run it for a while and i got a pretty good handful of rust out of it when i took it back off
Last Edit: August 27, 2016, 11:38:12 AM by fryedaddy
Re: flushing rust out of a running cars engine
Reply #3 on:
August 27, 2016, 02:55:49 PM »
One more tip. We found long ago that any Chrysler V-8 (Dodge, Plymouth) with a 383-440 often had terrible issues with cooling system rust as the cast iron used was prone to rust buildup even with proper care and the right anti-freeze. The thing we learned was to skip at first all the rust remover chemicals and just keep flushing the entire system with water until it came out clear....or as clear as one could get it. This could take a lot of effort to keep refilling, warming up, dumping the water and repeating the process. Then and only then would we add in chemicals designed to remove rust and start over again.
Last Edit: August 27, 2016, 03:59:25 PM by machoneman
Reply #4 on:
August 27, 2016, 03:25:48 PM »
great tip Bob,makes sense too.
