Author Topic: 520 cube, cast single four, Pro Ports, 824 hp, 745 tq  (Read 43351 times)
Re: 520 cube, cast single four, Pro Ports, 824 hp, 745 tq
« Reply #15 on: June 14, 2016, 10:15:34 PM »
Wow! Low tens here too! Tailwind and great bite....9.99!
KMcCullah
« Reply #16 on: June 15, 2016, 09:53:37 AM »
Congrats Cody on gettin' hitched. BP builds the best damn wedding gifts ever!  ;D Old Blue is gonna honk!  10.30's 130ish mph I'd bet...
Kevin McCullah
Rich P
« Reply #17 on: July 08, 2016, 09:18:55 PM »
I'm curious to know more about this great motor. What is the compression ratio? What is the bore and stroke? that's a great motor with great numbers congratulations.
CaptCobrajet
« Reply #18 on: July 09, 2016, 09:22:17 AM »
It is 4.345 bore x 4.375 stroke.  Around 13:1 static.  Heads are a variation of my "street" Pro Port Edelbrocks,  modified Victor manifold.  It only has .695 lift at the valve....very reliable solid roller that I use in many builds.  There is some more power in a bigger cam, but one of the goals was not to build a psrts-breaker valvetrain.
Blair Patrick
Russ67Scode
« Reply #19 on: July 28, 2016, 07:51:18 PM »
9.78,  @ 138 mph
bluef100fe
« Reply #20 on: October 05, 2016, 11:58:44 AM »
Small update on this engine, I have it installed in the truck and drove it around the block a few times, tried to run it at the last race of the year at my local track... but Mother Nature didnt cooperate so now I gotta decide if I want to travel to see what it will do this fall or wait till spring.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
fastback 427
« Reply #21 on: October 05, 2016, 01:05:07 PM »
How did the monster feel? Very cool, can't wait to see how it does.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
bluef100fe
« Reply #22 on: October 05, 2016, 08:21:49 PM »
It's a handful... need to add an electric fuel pump and still get the new rearend installed but it scoots as is...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
XR7
« Reply #23 on: October 06, 2016, 09:03:56 PM »
Cody! I think you need to travel!  ;)
bluef100fe
« Reply #24 on: October 01, 2017, 11:17:54 AM »
Well, a little update on the 520 deal, it's been a very very long road to get to the this point, but I'm glad to say I finally got the truck down the track with the new engine and almost all the updates on the truck, new rearend with back brace and disk brakes, home fabricated rear suspension, rollbar, trans shield, etc. Still on the to do list: is widen the wheel tubs and reinstall, build a new floor for the box, run second fuel line for fuel system, probably change rear gear, and converter. I made four passes  Friday at the street car event at kaukauna wi. First test pass was 11.26 @ 118 short shifting and using two step, second was pass was 10.77 @ 124 leaving against the converter and not short shifting, 3rd pass was after changing from my dambest 980 cfm 4150 flanged carb to my 1150 dominator carb and was rewarded with a 10.56 @ 126, all these passes and only going threw the traps about 5800-5900 rpm with the 4.10 gear and 31.5 tall tire. 4th and final pass I changed to my new drag radials which are only 27.8 tall and about 12" wide, track was cold and I did a huge burnout to break them in but they were probably to hot and the mistress just knocked em off leaving the line, so I pedaled her once and got right back in it and went 10.69 @ 128 despite losing over 2 tenths at the 60 ft, but the shift lite was on before I crossed the finish so it definetly wants more gear. For a first outing on a marginal cold track, on a bunch of new never tested parts I'm fairly happy, there's more in it for sure. Truck weighs about 4100 lbs after all the changes, and it's probably gonna be closer to 4200 after it's finished with me in it, Shes heavy.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #25 on: October 01, 2017, 11:44:32 AM »
Cody, that is smokin' in that truck!  Can't wait to see what she'll do when all dialed in.  Drag Week next year?
« Reply #26 on: October 01, 2017, 12:55:25 PM »
...3rd pass...was rewarded with a 10.56 @ 126,....
....I'm fairly happy,
Talk about a tough customer!..lol
That's awesome, Cody! It's pretty evident that at least 10.40s are in your future, if not 10.30s.
Just out of curiosity, I know peak power was made at 6500, but what is your redline set at? Most people I watch are stretching the RPMs at the top end, lighting the shift lite well before the finish line.
« Last Edit: October 01, 2017, 12:58:56 PM by cjshaker »
« Reply #27 on: October 01, 2017, 01:23:30 PM »
Very cool!
bluef100fe
« Reply #28 on: October 01, 2017, 05:22:48 PM »
Redline? What's that used for? Lol, I hit the recall on the Tach and it said 7400, which is where I got the rev limiter set I think. Shift lite is set for 6600 and 6800. Converter was setup tight on purpose, and I really don't want to put 4.57/4.86 gears in it for street driving, so I need to find some more power, less weight, or get the short tire to work at the track with the truck. Yes I want to run drag week but I was a couple weeks short this year, maybe next year if it's not too far away.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #29 on: October 04, 2017, 03:25:46 PM »
Link to some video footage from Facebook... https://www.facebook.com/ladowski/posts/10212109799714682
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
