Author Topic: Fairlane Time Slip  (Read 12769 times)
Fairlane Time Slip
« on: May 29, 2016, 09:13:53 PM »
Had a great weekend.
The car ran great, couple of issues, mostly operator.
427LX
Re: Fairlane Time Slip
« Reply #1 on: May 29, 2016, 09:45:10 PM »
NICE!  What's the setup?
« Reply #2 on: May 29, 2016, 09:50:43 PM »
Nice Howie glad your day was good and nothing broke. Was that your only run
« Reply #3 on: May 29, 2016, 10:03:16 PM »
Very Basic 428, small solid roller with stock Ed heads and RPM intake.
Jerico 4 sp and a soft loc.
« Reply #4 on: May 29, 2016, 10:07:18 PM »
Made 10 runs, the piece of junk tach started to fall apart. lol
Yellow Truck
« Reply #5 on: May 29, 2016, 10:08:52 PM »
Nicely done, Howie. Love to see air under both tires.
Paul.
« Reply #6 on: May 30, 2016, 08:50:16 AM »
Congrats Howie! Looks good. :D
« Reply #7 on: May 30, 2016, 10:25:38 AM »
Really nice, Howie!!
« Reply #8 on: May 30, 2016, 10:29:18 AM »
good deal Howie,i like your fairlane.i bet you had a blast making ten passes
« Reply #9 on: May 30, 2016, 10:47:11 AM »
Thanks guys.
It was a blast!
The car was very consistent at 12.3ish so we dialed the 12.30.
Qual'ed on that at 12.35. Great run. Near the top of the ladder.
So like an idiot, I should turn the wick up. Bad plan.
Too Fast. ::)
« Reply #10 on: May 30, 2016, 02:27:04 PM »
what do you do to run 12.30's , shift early  ?? .... what's it run flat out ??..... nice front tire air !!
57 lima bean
« Reply #11 on: May 30, 2016, 04:19:50 PM »
« Reply #12 on: May 30, 2016, 04:22:59 PM »
Yes shift early and often. :P
Really I'm just going real slow and learning how to drive the thing.
I'm only letting the 428 spin to 6300 for now.
Someday I will put a big engine in it and then we will see what it can do. ;)
« Reply #14 on: May 30, 2016, 06:04:35 PM »
Play that launch back at .25 speed and you can see the rear porpoising bad, unloading the tires. I had a similar problem at Beaver because my shocks were set way too soft.
You can see your launch at 1/4 speed here:
https://youtu.be/IRzrzPM0yVQ?t=1m45s
Edit: I tried to set it at 1/4 speed, but I think you'll have to change it to that yourself under the "settings" in the lower right corner.
Compare it to mine unloading here:
https://youtu.be/y5mDOTExE_U
It allows the rear to rebound back up and lose all traction. Only difference I see is that yours doesn't seem to stop bouncing. What shocks and springs do you have on it?
Slow-mo is one of the greatest tools you can have for finding problems with your launch. Keep at it, Howie. Looks like you could knock a couple tenths off when you get it figured out.
« Last Edit: May 30, 2016, 06:06:09 PM by cjshaker »
