Author Topic: Galaxie turbo FE 390 build  (Read 34694 times)
fuelbender
« on: March 17, 2016, 11:54:52 AM »
Hi folks getting close to finishing my 66 galaxie turbo build.
Forged pistons, eagle rods. 230/236 @ .050 cam, ported Eddy heads, Garrett 4202 turbo,4" exhaust.  Programmable MSD 6AL2 & T56 speed trans hydraulic clutch conversion. Mustang Cobra 13" discs. I gotta hook up the intake, boost cooler and some more items and of course tune. The carburetor in the car is just for break in; I am modifying a double pumper for boost. My estimate should put it about 680 ish flywheel HP. We'll see.
free image upload
« Last Edit: May 08, 2016, 11:11:04 AM by fuelbender »
gdaddy01
Re: Galaxie 390 turbo build
« Reply #1 on: March 17, 2016, 02:11:41 PM »
no more room for the battery . that thing should have some good torque numbers , by the seat of the pants anyway .
fuelbender
« Reply #2 on: March 17, 2016, 03:13:58 PM »
yeah I had to put it in the trunk! :)
« Last Edit: April 03, 2016, 01:37:16 AM by fuelbender »
ToddK
« Reply #3 on: March 17, 2016, 05:36:49 PM »
Great project, I'll be watching closely. I've often thought about doing a turbo conversion on my car. What sort of boost are you planning g on running?
fuelbender
Re: 6 speed Galaxie 390 turbo build
« Reply #4 on: March 20, 2016, 07:53:56 PM »
10 lbs to start. Headers were a nightmare; took cutting and piecing two sets.
[img]/img]
« Last Edit: March 24, 2016, 02:48:05 PM by fuelbender »
fuelbender
Re: Galaxie turbo FE 390 build
« Reply #5 on: April 30, 2016, 10:22:47 PM »
« Last Edit: May 08, 2016, 11:05:17 AM by fuelbender »
« Reply #6 on: May 01, 2016, 08:06:56 AM »
That is a cool project!  What size is the turbo?
ec164
« Reply #7 on: May 01, 2016, 07:25:09 PM »
Cool, very cool idea, and will make a super sleeper.................Al
You're ahead in a Mercury......all the way
fuelbender
« Reply #8 on: May 02, 2016, 09:29:02 PM »
Garrett 4202a 74/84 T6. Took it for a spin at 8lbs WOW!Full boost at 3500 RPM. In 2nd at 45 MPH I floored it and spun the rear tires on boost.  I changed the powervalve to open sooner and went with smaller emulsion tube jets. Its hovering around 13/14-1 AFR and about 13 at boost. Gotta fine tune the running and boost retard curves. Water/meth and more boost after tuning!
« Last Edit: July 23, 2016, 06:12:50 PM by fuelbender »
64bird410
« Reply #9 on: May 15, 2016, 07:51:56 AM »
That build is awsome. I bet it's a ton of fun.
64bird410
« Reply #10 on: June 20, 2016, 12:11:19 AM »
Just wandering how this project is coming along. Any updates?
fuelbender
« Reply #11 on: July 10, 2016, 11:25:47 PM »
Put water / meth in it and got the jetting real close; had to put a QFT metering block and tap the carb for bleeds. ready to put on the dyno for fine tuning!
64bird410
« Reply #12 on: July 14, 2016, 03:21:03 AM »
Great to hear. Good luck on the dyno. I'm curious what water/meth nozzle sizes and pump pressure you are starting with and if you are going to measure your exhaust back pressure during the runs.  In any case I'm sure it's quite a thumper in that Gal!
fuelbender
« Reply #13 on: July 17, 2016, 06:24:39 PM »
OK took it to work; at 80 MPH car is pulling about 9-10" vacuum and spinning at 1900 RPM. The morning temp was low 70s and afternoon 81 degrees. 51 miles round trip MPG was slightly over 15 with no hood! AFR high 14s. Those two overdrive gears on the t56 work! Gonna fit the intercooler on and machine the compressor housing for a 76 mm wheel then Dyno time!
I put a guage on the exhaust pre turbine and got about a 1-1 back pressure to boost ratio. Not sure if thats right but after the new wheel goes on I'll see if I need a smaller A/R for the exhaust turbine housing currently a T6 1.15 A/R.  Love the car. A 1957 farilane y- block turbo will be next (I know its not an FE  ;)) If anyone is interseted in the jetting specs and mods of the Holley I can post them.
BTW I'm running 10-1 compression and no pinging on 91 octane on my tune.
Im using a Snow performance Boost cooler stage 1 and using the 625 ml/min nozzle. (pump says 300 psi)
« Last Edit: April 08, 2017, 10:35:40 PM by fuelbender »
64bird410
« Reply #14 on: July 26, 2016, 03:09:45 PM »
Great update! And good to hear of another turbo street engine running successfully with a "normal" compression ratio.  I havent done a turbo blow through carb set up, just used the ford eec fuelie stuff on small blocks and we made sure we had plenty of timing pulled as boost comes up and especially under low rpm and high boost cells to keep max cylinder pressure at bay.  I am curious why you are going to plumb in an intercooler with a Blow through set up using a water/alcohol kit?  I haven't got all my peices together for an fe based turbo kit yet but my basic plan was to run either a borg warner s475 or s480 or a pair of s366 and use the ford eec system using a holley single plane manifold and apply the same strategy learned from doing 351w and 302 stuff.  Sorry for all the questions but not alot of turbo fe builds out there yet lol.  And I'm a fan of your build!
